70+ ( Old Skool Club )
![]() Join Date: Nov 2003
1967-1972 Chev/GMC Truck Assembly Manual
So finally got an official 67-72 Factory Assembly manual. Its thick and loaded with info but finding the specific info you want is very time consuming as there is no index of whats where in it. Anyone have any info or ideas to find something quickly in the manual.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Who Changed This?
![]() Join Date: Jan 2013
Re: 1967-1972 Chev/GMC Truck Assembly Manual
There is an index circulating around here, somewhere. I downloaded it years ago, but can't find the link, now. I don't think that a spreadsheet will load as an attachment, but I'll give it a shot.
Guess not. Somebody else should be able to load it?
![]() Join Date: May 2010
Jim |
Who Changed This?
^ YESSS! I have it, but couldn't figure on how to load it up from my computer. Thanks for finding it. The OP should be happy.
Can someone explain how to read that. I don't understand what all the columns with the x's on the right.
![]() ![]() Join Date: Jan 2005
Member CS1972 created a PDF version of the factory assembly manual that is free to download. It allows you to do text searches, which makes it way easier to find stuff.
https://67-72chevytrucks.com/vboard/...d.php?t=833705 |
Just downloaded the manual but it seems the columns on the index don't match. How do you read the index?
1971 Chev C10 - 250ci L6 w/3 speed on the floor Upgrades: Power Steering 3 Core Radiator 7 Hole Gauge Cluster Power Brakes (Incoming!!..) 1971 350 (Incoming!!..) |
The Older Generation
You should have bought the CD. You can look up anything you want on it.... It has a search function. https://www.classicparts.com/1967-72...fo/04%2D631CD/ https://www.americanclassic.com/1967...fo/04%2D631CD/ LockDoc
+1 on the FSM being essentially a brick. I also got a copy of the spreadsheet from Steve and do not see how it correlates with anything
These repop FSM apparently do not have index. Same issue with my 1st gen Camaro |
#10 | |
![]() Join Date: May 2012
You see "doc.google.com" in the URL. You need to logon to google with your account. Then you can select "File" in the spreadsheet menu and select "Download". you can download as .xls OR .pdf. The options are locked until you login to google. ![]() j
White K20 |
While the images and info in the Repop FSM is valuable, without being able to have a readable index it is very tedious to find what you need. It has no page #'s to cross reference using an auxiliary spreadsheet index is...well.
The Haynes or Chilton manuals while not as detailed as an FSM, for me usually give me enough 411. The Haynes one is around $25 available at places like Amazon. Fortunately for any 50+ year old vehicle, there are forum specific sites like this with very helpful members. |
Who Changed This?
Thanks, but I downloaded it quite awhile back. I didn't remember where from.
#13 | |
![]() j
White K20 |
Thanks for all the responses.
#15 |
Can someone please explain how the directory works for the assembly manual? Nothing seems to line up, am I doing something wrong?
#16 | |
![]() ![]() Join Date: Feb 2009
The assembly pages are often random, and repetitive.
I have the index in a Word doc if needed. You get to spend perhaps an hour numbering every other page for 1065 pages, yikes. Quote:
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#17 |
http://67-72chevytrucks.com/vboard/s...d.php?t=558016
Has everything including a search feature. Use it all the time. |
#18 | |
