Old 05-12-2020, 11:03 PM   #1
bnokle
bnokle's Avatar
Brake pedal hole and hydro boost
I have another hole 1" down I think it is. Is this a good idea to increase the pedal resistance with the hydro boost? Its off an 02 2500 if that makes any difference. I also cut the end off the pushrod and dilled out the pushrod end from the old setup, stuck the two together and welded it. So now its adjustable.
bnokle is offline   Reply With Quote
Old 05-13-2020, 01:00 PM   #2
MDPotter
MDPotter's Avatar
Re: Brake pedal hole and hydro boost
I didn't do anything to change the pedal resistance. I just enlarged the stock hole in the firewall so the hydroboost slid through and made a new backing plate so it attaches to the brake pedal assembly studs. Stops on a dime and the pedal feel is just fine.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 05-13-2020, 02:38 PM   #3
bnokle
bnokle's Avatar
Cool. I'll try it in the stock hole first and see.
Old 12-24-2022, 10:33 AM   #4
Dleslie212
I just installed a hydroboost conversion on my 77. Does the brake pedal HAVE to be modified? Or is that only if it's not working properly? How would I be able to tell it needs to be modified?
Dleslie212 is offline   Reply With Quote
Old 12-24-2022, 11:01 AM   #5
Getter-Done
Getter-Done's Avatar
There are several good threads about this subject.
Link: https://67-72chevytrucks.com/vboard/...ght=hydroboost
Hope this helps.
The early bird gets the worm,
84 Chevy K-20
Old 03-20-2023, 06:50 PM   #6
Extended Power
Extended Power's Avatar
I bought a hydroboost that was meant for an earlier truck, but modified it to work on my ‘70.
Moving the rod down, is a bad idea, unless it straightens out the rod so it is more “inline” with the hydroboost. (Not angled away from it.)
In the instructions that came with the kit I got, it basically says to make the rod as straight as possible, so there is no binding at all.
I’m still finishing up my install.
I can’t use the rod end that came with the kit, as when I try to bolt it to the brake pedal arm, the bolt hits the steering column...so I have to use the stock end piece that uses a bolt which acts like a bushing.
Same thing, I have to get the length of the rod, and put the new rod, with the old rod, and weld them together.
Did you add an oil cooler, or remote reservoir on your install?
Extended Power is offline   Reply With Quote
Old 03-20-2023, 07:00 PM   #7
Dleslie212
No, no cooler or remote reservoir.
I took it out two weekends ago on its first drive out to BLM land to do some shooting, about an hour each direction. I knew I'd have to get on the freeway, so my brother and I left early to avoid traffic. About 15 minutes in, I started getting a really bad shutter when braking, and I could just smell roasting brakes.
I pulled over and found both front calipers just smoking. I ended up removing the booster rod, adjusting it out about a half inch, and reattaching to the brake pedal. It's been beautiful since then. I was basically riding the brakes without having to use my foot. After the hour drive back home I popped the hood to feel the booster hoses. They felt warm, but not hot or overly warm at all
The kit I bought is specifically designed for the rod to be cut down to whichever length is needed
Old 03-20-2023, 11:29 PM   #8
LockDoc
The Older Generation
LockDoc's Avatar
My Hydroboost install starts with post #284 and pretty much ends with #298 in my build thread. Post #298 shows what I did with my pedal rod.
http://67-72chevytrucks.com/vboard/s...829820&page=12
LockDoc
Leon
