Old 04-23-2023, 12:56 PM   #1
Turtleman
Turtleman's Avatar
Motor Mounts
Currently swapping out the previous owners motor (68-72 sbc) with a 5.7 350.
Once it was out I see the previous owner made some engine mounts that set the motor so far back in the opening you couldn't get the distributor cap off. Now I'm wondering why someone would do that?, couldn't measure right, didn't know better,, who knows,,
So I have to ask, what's the issue with dropping the 5.7,sbc with a clutch fan in the so the distributor is off the firewall and sets back far enough to I have space behind the radiator?
Someone here's done it before, so can anyone recommend a/the correct motor mount to use?
Turtleman is offline   Reply With Quote
Old 04-23-2023, 05:54 PM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: Motor Mounts
What year truck are you working on?
Please post some pictures of the motor mounts in question. That will help us help you.
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 04-23-2023, 07:07 PM   #3
Turtleman
Turtleman's Avatar
Re: Motor Mounts
66 C-10
kind of straight forward, here's a image of the home made lower mount;
https://www.dropbox.com/s/qqh5uqtqjs...54038.jpg?dl=0
heres the cross member;
https://www.dropbox.com/s/3cmwav9rs7...54050.jpg?dl=0
heres the image of the OEM mount;
https://www.dropbox.com/s/ep55yj17dw...54354.jpg?dl=0
I do Not Need a OEM lower mount plate, I wouldn't mind that if I can find one that will set my engine in without jamming my distributor against the firewall. Any after market mount will do so that's why I'm asking any one that's dropped a 350 SBC in their C-10 that's fits without being against the firewall and the oil pan clears the cross member, along with space between the fan and the radiator. I use a clutch fan so it add's another inch or more...
Anyone that can point me the right direction so I'm not pulling all this stuff out later and trying something else?
Old 04-24-2023, 10:02 PM   #4
cwcarpenter98
Re: Motor Mounts
What you need is the stock, 63-66 frame stands that were used with the 230 and 250 inline 6 and 283 and 327 v8s. They will also work with your later year 350 with the correct 63-66 v8 block mount. The HEI will be close to the firewall, but it will fit and you can take the cap on and off. I've still got a 283 in my 63, but it has an HEI and I don't have any issues with it.
Regarding your clutch fan, if you want to run a factory v8 shroud, you'll need a short water pump instead of the later year long water pump. A 65 Impala fan clutch and 5 blade fan fits perfectly with a short water pump and factory shroud for the 63-66 trucks.
The pic below shows where the frame stands you need mount to the frame and where the engine sits in the factory v8 location with an HEI
Christian Carpenter
Old 04-24-2023, 11:26 PM   #5
Turtleman
Turtleman's Avatar
Re: Motor Mounts
Excellent information CW.. just what I needed to know
Thank You Very Much
Old 04-24-2023, 11:35 PM   #6
cwcarpenter98
Re: Motor Mounts
Happy to help!
Christian Carpenter
