![]() Join Date: Oct 2012
frame number
I have a frame from 64-66 I think. Anyway here is the number under the drivers side cab on the side of the frame 3829589 1 L 6 25 108 can someone decode this and tell me the year. Thanks
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
![]() ![]() Join Date: Apr 2012
Re: frame number
3829589 is the part number for that sides frame rail . The rest is a production code or possibly a date. I haven't figured that out yet
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
![]() ![]() ![]() Join Date: Jan 2018
Re: frame number
Any numbers on top of the driver’s side frame just in front of the engine mounts?
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Re: frame number
Re: frame number
Same deal with my 63. Part of why I'm going to attempt to save the cab instead of just doing a cab swap with one that has less rust
Re: frame number
Yes there is numbers on the top of the frame before the steering box. I cant make them out. I was just hopping someone could tell me the year of the frame
