Old 06-11-2023, 10:28 PM   #1
RonWT
Active Member
RonWT's Avatar
rear drums and shoes on a 69
I changed out the shoes and drums on the back of our 69 CST10 today, I havent worked with drum brakes since High school (40) years ago. I seem to remember my dad telling me to have a place to put the truck in reverse and stab the brakes and do it till they are adjusted, I seem to remember doing that and it worked. The drums do not have any hole for the adjusting tool, nor do the backing plates. is the process I described above correct or is there another way to adjust the new shoes to the drums?
Thank you,
RonWT
RonWT is offline   Reply With Quote
Old 06-11-2023, 11:06 PM   #2
franken
Re: rear drums and shoes on a 69
Sounds right if the self-adjusting hardware is there.
Adjust the clearance until the brakes just drag a bit them back off a hair.
There could be a knockout in the drum or backing plate to allow for manual adjustment.
Old 06-11-2023, 11:19 PM   #3
RonWT
Active Member
RonWT's Avatar
Thank you for your reply, like I said, it's been 40 years. I am sure all the hardware was the re. I think it's good to go now, until I can get a disk conversion.
Old 06-12-2023, 01:11 AM   #4
pjmoreland
pjmoreland's Avatar
The rear drums on my truck didn't have the adjustment slots, so I added the slots with a drill and a file.
pjmoreland is offline   Reply With Quote
Old 06-16-2023, 12:12 AM   #5
geezer#99
geezer#99's Avatar
You forgot the plug for the slot.
https://www.ebay.com/itm/1x-GM-Rubbe..._redirect=true
