![]() Join Date: Oct 2001
Alternative rear blazer seat?
Anyone using a different seat and if yes what did it come from, my blazer doesn't have a rear seat at all.
Thanxs
Things happen for a reason! |
![]() Join Date: Jan 2001
Re: Alternative rear blazer seat?
I have two rear seats, both from Yukon XLs. I had to fabricate a bracket, but with my front bench seat, I can carry 9 people.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
![]() Join Date: Feb 2009
Square body rear Blazer seats work well and are inexpensive and easy to find
#4 | |
Thanxs guy's
Active Member
![]() Join Date: Jun 2021
I dont have pics but I used a Bifold rear seat from a Burb..(I think)..it will fold up against the back of the front seats
#6 | |
Thanxs
The old square body blaz and burb rear fold and tumble seats used to be popular when they were cheap in the salvage yards. Getting tougher to find them reasonably priced these days.
The width between wheel wells of the 69-72 Blazers is 50". The rear seat ("2nd row") of the newer 4 door Jeeps is 49". The TJ/YJ (classic 2 dr. jeeps) rear seat is fold & tumble, and has been used by many but is only about 34" wide ..perfect for one adult, two small kids or a dog, also installs offset to one side if extra transport/storage of longer items is needed. You can remove the headrests on most of the newer rear seat options to bring down the height if needed. |
Addicted user
If you want to use a rear seat that is more OEM size there is an aftermarket frame availible for the 69-72 blazers / jimmys now that some vendors on the site can likely supply. I have not been able to find a replacement foam for the rear seat frame though does anyone know if there is a foam option out there?
1972 2wd Blazer - 95% completed 2015 Silverado 1500 4wd -z 2008 AERO 9-7X (TBSS cousin) LS2 1970 Jimmy 4wd - future project |
Addicted user
#10 | |
Always on the hunt...
![]() Join Date: Sep 2006
available in the below linked f/s thread over on the blazer-suburban side of the parts board. Mel ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=838392 .
***For any return/past customers & friends*** Before sending of any funds, please wait for a confirmed total and instructions for sending as our payment account info has been changed as of Jan. 2023. Thanks... |
Mine is the 3rd row from an 83 Burb; I welded in the floor brackets from the burb and the seat folds AND is removable. Sits BETWEEN the wheelwells too.
'72 K5, known as 'the Fox.' |
![]() Join Date: Apr 2006
PRP will make a bench seat in whatever width and color scheme you want. All you have to do is make some brackets to mount it.
https://www.prpseats.com/product/cus...ch-seat-36-48/
Kirk 72 Blazer CST 4wd highlander |
Active Member
Yep same as mine!..I had to weld in the buckets in the floor
It would be nice if they would reproduce the bucket seat frames.
#15 |
![]() Join Date: Oct 2006
#16 |
Found a backseat out of a 79 blazer, gonna work fine with some mods to the mounting brackets...
