Old 08-05-2023, 10:52 PM   #1
RonWT
Active Member
RonWT's Avatar
Hei or points??
Folks, I am wondeing how many of you are still running the old points style ignition or if you have converted to HEI? if you converted, what style of HEI have you went to?
Thanks,
RonWT
RonWT is offline   Reply With Quote
Old 08-06-2023, 01:24 AM   #2
CastIron
CastIron's Avatar
Re: Hei or points??
After watching the timing bounce all over at idle, I decided to replace my original distributor with a MSD street fire HEI distributor. It runs much better, but that might also be because I replaced a tired 307 with a crate 350 at the same time.
CastIron is offline   Reply With Quote
Old 08-06-2023, 02:46 AM   #3
Wikid61
Wikid61's Avatar
Re: Hei or points??
HEI that is tight may step up the spark a lot. Especially using quality cap/rotor/wires/ect. Another option is this: https://pertronixbrands.com/ I've ran them & the stock cap tales up less space.
"Envy is a declaration of inferiority". Napoleon Bonaparte.
Wikid61 is offline   Reply With Quote
Old 08-06-2023, 04:25 AM   #4
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: Hei or points??
I found a definite performance improvement when converting to HEI. I've done it on V8s as well as my L6.
I ran PerTronix for about 7 years, but it burned out on me.
GM Delco-Remy style HEI is the best, and parts are universally available in the US.
Old 08-06-2023, 08:03 AM   #5
don t. - 72gmc
Re: Hei or points??
I converted to a Skip White HEI dizzy years ago. The original dizzy, bad bushings made it wobble. At that time, $'s were tight, wanted something quick and easy.
Getting the truck back on the road this summer, wanted to R&R the cap and rotor. Skip White does not sell parts, but would sell me a new dizzy. Local auto parts guy I trust thinks he may have found an Excel cap & rotor. Parts arrive on Tuesday.
Good luck...Don
don t. - 72gmc is offline   Reply With Quote
Old 08-06-2023, 10:14 AM   #6
truckster
truckster's Avatar
Re: Hei or points??
I had a factory HEI for years. I decided to upgrade to a Progression Ignition distributor a few months ago and I couldn't be happier. It connects to your phone via Bluetooth and allows you to custom program timing maps on the fly. It also has a lockout function that will keep your vehicle from starting if you lock it on the app.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 08-06-2023, 11:54 AM   #7
yuccales
yuccales's Avatar
Re: Hei or points??
Member of the "Points Forever" club here. Both my old dogs still run em. I just can't part with the old Penske.
yuccales is offline   Reply With Quote
Old 08-06-2023, 12:00 PM   #8
697498chevy
Re: Hei or points??
My '69 C 10 also has O.E. distributor . Seems to run fine . Thanks
697498chevy is offline   Reply With Quote
Old 08-06-2023, 12:10 PM   #9
Getter-Done
Getter-Done's Avatar
Re: Hei or points??
I still have the Penske my Daddy used and that I was trained on.
The early bird gets the worm,
84 Chevy K-20
Old 08-06-2023, 01:35 PM   #10
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Hei or points??
I converted to a used late-Seventies GM HEI back in the early 1980s and couldn't be happier with it.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 08-06-2023, 02:12 PM   #11
Wrenchbender Ret
Re: Hei or points??
I have kept the points & cond. because I want to keep everything original on my low mileage 72 Super. I have a GM HEI unit that I have o-hauled that I could put on it but it runs & starts perfectly.
George
Wrenchbender Ret is offline   Reply With Quote
Old 08-06-2023, 02:22 PM   #12
Re: Hei or points??
That's what i have on my 70. I think only issue in last 25 years was 2 module died. Super dependable.
Old 08-06-2023, 02:33 PM   #13
Rust_never_sleeps
Rust_never_sleeps's Avatar
Re: Hei or points??
Still running points. When the original dizzy wears out, I'll think about HEI
Rust_never_sleeps is offline   Reply With Quote
Old 08-06-2023, 02:35 PM   #14
Rust_never_sleeps
Re: Hei or points??
You're a pretty hardcore "Belt and suspenders" guy ;-)
Old 08-06-2023, 02:36 PM   #15
dmjlambert
dmjlambert's Avatar
Re: Hei or points??
I have a used 1976 to 1980 GM HEI in mine and I like it.
Old 08-06-2023, 03:25 PM   #16
body bolt
Re: Hei or points??
I added HEI 25 years ago and haven't touched the distributor since.
body bolt is offline   Reply With Quote
Old 08-06-2023, 04:18 PM   #17
54blackhornet
54blackhornet's Avatar
Re: Hei or points??
Not being able to find an original GM HEI I bought a clone off eBay from a firm named BraveX. Billet aluminum housing and good quality oil impregnated drive gear. Cap looks good too. BUT everything electrical is very low quality. The first one lasted about a year before the module died. BraveX replaced it with no questions. Second one lasted about two months. BraveX again replaced it. Third one is in and running great. Let’s see how it goes ? Another problem I have determined is you can’t buy anything under the cap that’s made in the USA any longer.
71 C-20
07 Magnum RT AWD
54blackhornet is online now   Reply With Quote
Old 08-06-2023, 04:50 PM   #18
72c20customcamper
72c20customcamper's Avatar
Re: Hei or points??
Two with factory GM HEI and two still with points they all run well
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
72c20customcamper is online now   Reply With Quote
Old 08-06-2023, 05:40 PM   #19
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
Re: Hei or points??
Im another one for points. My C10 had a HEI when I bought it and tossed that quickly and went back to points. Pretty much all of my old cars run points. Never have had a issue with them, have had more issues with conversion kits and electronic billet distributors than with points. I check the dwell about once a year, but usually they are still right on where I want them, so pretty hassle free.
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 08-06-2023, 06:31 PM   #20
kwmech
Re: Hei or points??
Changed all my trucks over the HEI, hell I've even got one on my toyota. I got tires of stretching all way back to the fire wall to get a little screw out that eventually falls never to be found again. Got the meter and the special adj tool. I still keep the point systems and have them filed away in a box to convert back if needed with brand new parts also, including the resister wire.
Old 08-06-2023, 11:55 PM   #21
RonWT
Active Member
RonWT's Avatar
Re: Hei or points??
Man, what a great response from you guys, I am running points now, and no problems at all, I just started thinking that a HEI system may be better. Thanks folks for replying to my questions.
Old 08-07-2023, 12:26 AM   #22
mr48chev
mr48chev's Avatar
Re: Hei or points??
When I still had the 350 in my 71 with points it was getting hard to start and just flat wasn't running all that good even with careful tuning. I bought a Skip White Distributor simply because I could buy the complete new unit mailed to the house for less than I could get a cap, rotor and module for one of the Hei's I have hanging in the garage and I have several. If you saw what I deleated, the 10 week old kitten was walking across the keyboard.
The change was immediate, far easier starting and 2+ mpg gain in mileage.
There is only one advantage to points, If they burn and you stall out you can get out an emory board or piece of sandpaper or point file (who carries one of those) and clean off the contacts and eyeball set the points and go again. The bad is that you normally change them every10K miles if you actually drive the truck. Years ago that wasn't bad when you could get good points and a condensor for under 10 dollars and change and go again.
With an Hei it isn't unusual to go well over 50 K before you decide that maybe you need to look at the cap and rotor and the plugs that are available now are often good for up to 100K rather then ten or 20K.
I totally respect keeping it "original" but the guys who have fully restored "original" down to the tread design of the tires usually don't put many miles on their trucks and often guys with modifiied or slightly modified trucks are racking up serious miles simply because the truck is fun to drive.
My ongoing truck projects:
Old 08-07-2023, 12:49 AM   #23
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Re: Hei or points??
No points, no distributor, no carburetors, LS and loving it
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 08-07-2023, 12:55 AM   #24
Rust_never_sleeps
Re: Hei or points??
Does that thing do other tricks besides dwell?
Old 08-07-2023, 07:31 AM   #25
yuccales
yuccales's Avatar
Re: Hei or points??
Volts, ohms, rpm. For my early years that was my only "real" tester. Nowadays it just is my dwell meter.
