Old 08-30-2023, 12:53 PM   #1
66gmcguy
Are these original beauty rings?
I bought a set of 6 lug rally wheels that the guy claimed had original beauty rings and caps. The caps appear to be original since they are die cast aluminum and not plastic, but I've never seen this style of beauty ring before. I am thinking of selling the set of caps and rings and don't want to advertise them as original if they aren't. Also, what is a decent driver-quality set of 6 lug caps and rings worth?
66gmcguy is offline   Reply With Quote
Old 08-30-2023, 02:24 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Are these original beauty rings?
Original trim rings are more chamfered/beveled in appearance (not as rounded) and have a different clip arrangement.
Unless those are for a different wheel width?
Original trim rings (1987 model year, 15x8" wheel):
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 08-30-2023, 02:27 PM   #3
66gmcguy
Original trim rings:
Thanks Keith. The clips are what gave it away for me.
Old 08-31-2023, 03:36 PM   #4
HOTFUN
HOTFUN's Avatar
Actually those are correct 1st design trim rings with 4 attaching point clips. The 2nd design 1976 on were the 12 point attaching style as Keith has pictured in his truck.
The N67 rally wheel option appeared later as an option during the 1973 model year and had several distinct differences until the 1978 models came out. As per my 1977 print parts book the trim rings with "4" clips were K10 models and Blazer 1973-1975. 2nd design used from 1976 on. The early caps were also taller at 4 7/8ths versus the later caps 1976 on at 4.25". This was because GM only had used full closed caps with insert medallions for GMC and bowtie on all four wheels covering the full time 203 cap. Then in 1978 GM made the rear closed caps only with the new 4x4 medallion. I believe the few 205 gear drive systems with spicer knobs were not available with N67 wheels due to no open rally wheel caps on the scene till 1976. All caps from 73-77 were painted trim black around the base not silver as all later ones were till end of production. Also of importance was all the early caps used 1/4" bolts/ casting holes and the 1978 on wheels were made with silver base color and used 5/16 for the mounting screws/ casting holes. GM also in 1978? started making the N67 15x8 rally wheel with cap mount holes drilled at 1/4 " and alternating 5/16 holes to mount either size GM caps. All factory screws were self tapping but were given seperate part # for either size in the late 1970's. I've done a lot of research on the early N67 rally wheels. Here is the GM Parts Book info for my basis on 4 clip 15" trim rings in group 5.871 for the trim ring info and years used.
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 factory #'s V8 stepside project
'72 Cheyenne K20 50k original
'72 CST Blazer K5 owned 30+yrs
'73 Sierra swb 4x4
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
Old 09-01-2023, 12:18 PM   #5
66gmcguy
Wow, that's some good info. I love this forum. Thank you sir!
Old 09-01-2023, 10:24 PM   #6
Willowrun
Willowrun's Avatar
Agree. Great info.
