Old 06-18-2023, 02:35 AM   #1
Rufas
Rufas's Avatar
Door seals?
I have a 1970 GMC with the push on doors seals and my doors are extremely difficult to close. The doors close fine without the seals installed. 'IF' I remember correctly I got the seals from Brothers Trucks before Holley took over. I finished the truck 5 years ago, but don't drive it often, so I have just been living with it.
I've spent the last few hours researching 'door seals' here on this site. There are lots of threads that are years old. There are so many threads about glue on, push on, Honda Civic doors seals (I have found new seals), and Dodge Dakota doors seals.
Things change over time. Who has had good luck with getting doors to shut without slamming and what seals did you use?
1970 GMC 2500
700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles.
350 SBC 300hp
Weiand Supercharger
FiTech 30004 EFI
Rufas is offline   Reply With Quote
Old 06-18-2023, 08:09 AM   #2
best view
Re: Door seals?
First Beautiful truck , second never have trouble , I make my body guy do it
best view is offline   Reply With Quote
Old 06-18-2023, 08:32 AM   #3
cornerstone
cornerstone's Avatar
Re: Door seals?
You can remove the door seal, close the door and get in the truck to see if the gap where the seal resides is tighter in any particular area. If you find a tight spot you can use a set of wide jaw vise grips and gently bend the metal that seal attaches to away from the door to create more room for the seals. Pay particular attention to the front edge of the door near the hinges. Good luck.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 06-18-2023, 09:04 AM   #4
Joyridin
Re: Door seals?
Get the Honda Civic door seals. They fit absolutely perfect, are super easy to install, and really do not look a whole lot different than the factory version.
Joyridin is offline   Reply With Quote
Old 06-18-2023, 10:12 AM   #5
Trio
Trio's Avatar
Re: Door seals?
Have a link, or what year / model / trim of Civic specifically?
Trio
1971 C20 350/700R4
Trio is offline   Reply With Quote
Old 06-18-2023, 10:43 AM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Re: Door seals?
Check this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=741910
I just installed the '06 door seals on my Dually project. It it took me longer to get them off of the Honda than it did to install them on my truck. They fit perfect and the doors shut perfect.
LockDoc
Leon
Old 06-18-2023, 12:37 PM   #7
Extended Power
Extended Power's Avatar
Re: Door seals?
My truck had the glue on seals...which didn't seal at all.
Then I bought Brother's Truck seals, which were push on, and had to wind up, and slam the doors, like I was mad at the world, every time I tried to close a door.
Then I bought brand new Honda door seals.
They fit perfect, seal good, and.....no cut to the right length BS. They are seamless...one piece.
These are the Honda part numbers I ordered for my 1970 GMC 1/2 ton.
"If it ain't broken, fix it 'till it is!"
Extended Power is offline   Reply With Quote
Old 06-18-2023, 12:47 PM   #8
Rufas
Rufas's Avatar
Re: Door seals?
"IF" I researched this correctly from the referenced thread above. You need seals from a 2006-2011 Honda Civic DX 2 door.
Left Door
Right Door
1970 GMC 2500
350 SBC 300hp
Weiand Supercharger
FiTech 30004 EFI
Old 06-18-2023, 05:46 PM   #9
chevy71super
Re: Door seals?
I used new Honda seals. They work well but are not a cure all for tight fitting doors . . . ask me how I know.
71 Cheyenne Super 4X4 SB
72 Cheyenne Super 4X4 SB
72 Cheyenne 4X4 SB
chevy71super is offline   Reply With Quote
Old 06-18-2023, 09:03 PM   #10
Trio
Trio's Avatar
Re: Door seals?
Originally Posted by LockDoc View Post
Check this thread.
LockDoc
Left Door
Right Door
Thanks to all, very helpful as usual!
Trio
1971 C20 350/700R4
Old 06-19-2023, 07:45 AM   #11
Joyridin
Re: Door seals?
Here you go:
72315-SVA-A01ZA Seal, R Front Door Opening *NH167L* (Graphite Black)
72355-SVA-A01ZA Seal, L Front Door Opening *NH167L* (Graphite Black)
Old 06-19-2023, 10:36 AM   #12
72c20customcamper
72c20customcamper's Avatar
Re: Door seals?
I got the push on seals from Classic parts . Pretty sure they were Precision . Fit was perfect and the doors close easily not as easy as say my 2021 Cherokee but I don’t have to slam them . The doors need to be adjusted properly in order to work it helped I didn’t have the fenders on at the time . Also there needs to be a small gap at the bottom so the air inside the seal can escape.
If you have to slam the door have you tried to open the window slightly ? Sometimes the truck is so tight that the air has no where to go . My 85 I leave the cowl vent open slightly and the doors shut much better . I did this after noticing that the door shut easily when the window was open closed not so much
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 06-19-2023, 06:07 PM   #13
67C10Step
67C10Step's Avatar
Re: Door seals?
I got a new set of of push on seals from Steele Rubber about two months ago. They went on fantastic and did require some oomph but that is lessening now. If one of the windows is cracked it helps but when you want to shut it with all the windows up it takes a push.
I noticed most new vehicles have a number of holes to let the air out of the seal. I was wondering if I could do that in a few places around the perimeter and it improve the closing without comprising the seal tightness.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 06-19-2023, 06:15 PM   #14
Rufas
Rufas's Avatar
Re: Door seals?
Originally Posted by 67C10Step View Post
I got a new set of of push on seals from Steele Rubber about two months ago. They went on fantastic and did require some oomph but that is lessening now. If one of the windows is cracked it helps but when you want to shut it with all the windows up it takes a push?
I like that idea. But what method would you use to put holes in these seals.
I think drilling would be a bad idea or using a hot soldering pencil seems like it would be messy and look bad.
1970 GMC 2500
350 SBC 300hp
Weiand Supercharger
FiTech 30004 EFI
Old 06-19-2023, 06:35 PM   #15
DA71Grande
DA71Grande's Avatar
Re: Door seals?
Id be cautious with Steele Rubber I’ve had mine on for a couple of years now and have developed creases in the upper corners on both sides that leak.
Doug
71 Sierra Grande C25
16 Sierra 2500HD All Terrain
23 Chevy Tahoe Z71
https://paypal.me/digdug7131?locale.x=en_US
DA71Grande is offline   Reply With Quote
Old 06-19-2023, 07:15 PM   #16
67C10Step
67C10Step's Avatar
Re: Door seals?
Not sure but I’ve not put a lot of thought into just yet either. I know drilling is out and figured any sort of heated thing would be a bit messy and inconsistent. I’ll ponder it a bit and I kept a few of the short pieces I trimmed off. Will practice on those.
As to the creases I’ll watch for those but it seems odd for them to form like that.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 06-25-2023, 12:49 AM   #17
coldrider
Re: Door seals?
I ordered the exact ones referenced above and in the other other thread (# 72315 & 72355). Its interesting that some folks have said they fit with no cutting at all, one person said they were too short, and a couple of folks have said they were too long and needed to be trimmed.
I just installed mine tonight and I had to trim 2" out of them to fit my 67. Not a big deal at all.
Without changing anything else, these definitely reduced the amount of effort required to close the door. I only have a single test drive with them, but I didn't notice any changes to noise level / sealing
I had push on seals before but I don't know what brand they were as the prior owner installed them. FWIW, I figured I'd post up a quick picture of the Honda cross section vs Stock/Aftermarket replacement. Civic on the left, Chevy on the right. Pretty obvious which is going to be easier to compress.
Also note the arrow showing the extra little flap on the civic seal that sits inside the cab. IMO, its not super noticeable unless you're looking for it, but I'll probably end up trimming it off
coldrider is offline   Reply With Quote
Old 06-25-2023, 03:12 AM   #18
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Door seals?
My new precision seals are alright. You have to trim them, big deal. I had to slam the doors at first. RH is real nice now. Adjusted the LH striker a pinch for an improvement, seems it needed it anyway.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 06-25-2023, 07:44 AM   #19
Joyridin
Re: Door seals?
I bought the part numbers I referenced in my post from a Honda dealer. They are 1 piece. They fit perfectly. I had them on in 5 minutes.
Old 06-25-2023, 10:57 AM   #20
coldrider
Re: Door seals?
Yep, just to be clear, I ordered the same ones, also from a dealer, they were one-piece continuous loop before I cut them to fit
Old 06-25-2023, 01:05 PM   #21
PbFut
Re: Door seals?
Anyone want to part with their used too tight push on door seals? I have some wind noise and unsure if it's window or door, or both seals failing.
PbFut is offline   Reply With Quote
Old 06-26-2023, 11:03 AM   #22
coldrider
Re: Door seals?
pm sent
Old 10-02-2023, 06:37 PM   #23
Rufas
Rufas's Avatar
Re: Door seals?
****UPDATE****
I'm the op on this thread. This summer I started this thread and learned about the Honda Civic door seals. Back in June, where we were in Atlanta, I decided to try and locate these seals. I did find a pair in one of those "U-Pick_It" salvage yards. I cleaned the seals up a put them away until we got back home.
We got back home a few weeks ago and today I decided to try these Honda seal.
WOW! These seals are fantastic and a perfect fit without cutting anything. The seals fit a little loose, but I found out just squeezing the channel together makes them fit snug.
But the best thing is I can close my door without slamming them. It's just a gentle push and the doors close effortlessly. The total cost was just $20 bucks!
I highly recommend to those having trouble closing their truck doors to try these seals. You won't be disappointed.
1970 GMC 2500
350 SBC 300hp
Weiand Supercharger
FiTech 30004 EFI
Old 10-02-2023, 07:46 PM   #24
71CHEVYSHORTBED402
Re: Door seals?
Tell you one thing, check all your door hinge bolts sometime(s) after installing door seals. And a door hinge wrench (e.g. Snap On 9/16 " S 9607) is a must have at the pillars.
Tony
Old 10-03-2023, 01:18 PM   #25
weq92f
weq92f's Avatar
Re: Door seals?
This thing here...
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
