Old 10-03-2023, 08:08 PM   #1
olblue81
olblue81's Avatar
Dual tank problem: appears to switch side but only seems to draw off left tank
1981 GMC longbed 2wd. Just got home from a 2500 mile trip to Cruise to the Woods in Iowa. The switch and valve have worked fine for years and for 1800 of those miles. I was running on the left tank and getting low, so I filled up both tanks and selected the right tank. I drove 1.5 hours and noticed the fuel gauge had not dropped. I switched to the left tank and saw that it was down below half. I switched back to the right and gauge goes up. My next fuel stop I see that the right tank still selected, still shows full. I filled the left tank and it took 14 gallons yet I had selected the right tank. Tried topping off right tank and it was completely full. I drove 3 hours with the right tank selected and gauge never dropped. Switched to left and sure enough, it's just above empty. I got home stopping every 2 hours to fill the left tank and quit trying to switch.
I haven't got any tools out yet but I did turn the key on/engine off, tried the switch and I can hear the motor in the selector valve move. Is it possible for the valve to fail internally so it continues to only draw from the left tank despite the motor moving?
Stu-
1981 GMC Sierra Classic LWB
355- original 2 bolt block, 10.2:1, vortec heads, Comp XE268 cam, built by self in 1992
700R4-2000 stall with lockup, shift kit, Corvette servo
3.07 open diff- I need a 3.73 posi!
2nd owner since 1986 - 388,000 km and counting. 100k by the first owner and the rest by me.
olblue81 is offline   Reply With Quote
dual tanks, selector valve
