![]() Join Date: Sep 2002
Rear ratio question
Can anyone tell me what the ratio would be for a 72 C10 posi rear (with leaf springs if that makes a difference)? The option sheet lists the posi, but no ratio. I was under the impression that a 3:73 would be listed separately as an option (was in another 72 I had, but no posi in that one), but not sure.
Any info is appreciated. Thanks guys. |
ttt
Watch out for your cornhole !
![]() Join Date: Jun 2003
MOST 350 trucks had 3.08
Thats the Hillbilly way
What engine and trans?
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
Bill72BB, I was told it was originally a 350 4-speed.
Thanks for the info. Scott |
20' Daredevil (Ret)
![]() Join Date: May 2003
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
Stocker, I haven't picked the truck up yet (72 parts truck). I want to get the truck mainly to use the posi in a 68 I have, but from what I understand I need to make sure the ratios are close in order to use the posi carrier in the 68 rear. The truck probably isn't worth getting if I can't use the rear.
thanks. Scott |
350 /4 speed 3.07 stock, 3.73or 4.11 optional
Ok, since you all are answering rear end questions. My 67 3/4 lwb originally had 6 cyl in it with I believe a 3 speed, this has all been replace with a 454 and a 400 TH. I have been told that the rear end is either a corporate or rockwell. How can I identify it and do any of you have any idea of what the ratio might be.
67 C20 LWB 454 BB THD 400 97 Jeep Wrangler 4cyl 5sp Last edited by padreisla; 01-13-2004 at 01:41 AM. |
your rearend is the eaton/corporate ho52. it should have 4.10 or 4.56 gears, i forget which was standard and which was optional though.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
Thanks to all for all the great info!
Hey 1969 GMC, were you referring to the rear end in my truck. If so I would really like to lower the gears, do you know where I might be able to get lower gears without breaking the bank? I was thinking about going to something around a 3:5?.
67 C20 LWB 454 BB THD 400 97 Jeep Wrangler 4cyl 5sp |
its all about the +6 inches
You'll be hard pressed to do it in reality...at least on a buget anyways.
