Old 06-15-2024, 09:44 AM   #1
1967GMCC20
1967GMCC20's Avatar
1968 Air Cleaner BBC
Looking for a 68 Big Block air cleaner for my 67 conversion.
I'm Going for stock look on the conversion.
Big blocks have shorter snout, larger area on inlet of snout.
At least on cars they do.
1967GMCC20 is offline   Reply With Quote
Old 06-15-2024, 09:53 AM   #2
Getter-Done
Getter-Done's Avatar
Re: 1968 Air Cleaner BBC
Link to ebay : https://www.ebay.com/itm/23539861219...Bk9SR7zdycKDZA
Your best bet would be Ebay or a swap meet unless you want to become a subscribing member then you could post a want to buy add
The early bird gets the worm,
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 06-15-2024, 09:55 AM   #3
1967GMCC20
1967GMCC20's Avatar
Thx.
Old 06-15-2024, 10:41 AM   #4
Steeveedee
Who Changed This?
Steeveedee's Avatar
Yup, look like my pic. I'd like one of those dual snorkel jobs but can't quite skin my wallet for it. Are you going to also install the tin for the exhaust manifold and heat tube?
~Steven
Simi Valley, CA
Old 06-15-2024, 12:37 PM   #5
1967GMCC20
1967GMCC20's Avatar
Yep, would have to buy heat shield. In Ohio need in Winter time.
Next will be oem valve covers I bought. But, these later models don't leak....
Old 06-15-2024, 03:38 PM   #6
68Gold/white
The air cleaner housing on my 68 396, has no warm air tube, or any way to connect one. It also does NOT have the vacuum pod on the snorkel. It's just a plain single snorkel air cleaner housing. In fact it's smaller than the link pictured, 71/72 unit. You'd think it would be fairly big............unless mine is incorrect.
I've never seen a 68 unit for sale, here. I'd like to find one I could afford, mine is a little rough...
68Gold/white is offline   Reply With Quote
Old 06-15-2024, 07:44 PM   #7
Steeveedee
Who Changed This?
Steeveedee's Avatar
Likely a unit from a year previous, before that heat tube was used. A smaller inlet size may mean that it was on a SBC. Then again, it could be a Federal emissions setup, Vs California emissions. That's long enough ago that I've forgotten the differences, even though I was an emissions tech in the '70s and '80s.
~Steven
Simi Valley, CA
Old 06-15-2024, 10:47 PM   #8
KQQL IT
At the body shop.
KQQL IT's Avatar
Some swap meet breather I believe sbc air cleaner base.
And bought another base for the matching snorkle. Hole saw and a few tacs, dual intake for about $50
Old 06-16-2024, 09:23 PM   #9
68Gold/white
I don't know. The exhaust manifold has no sheet metal attached for the breather tube...
I bought my 68 in 1980. Everything on it was stock...although wore out.
Old 06-16-2024, 10:15 PM   #10
Steeveedee
Who Changed This?
Steeveedee's Avatar
My truck's air cleaner housing (the picture is mine) has the vacuum motor, but no indication at all that it ever had the sheet metal. Given that this truck ran hot from the very first day my FiL bought it, I'm betting he removed it. That, or when he had the engine rebuilt 40 years ago, it got left off. They put the heads back on opposite sides too, because the coolant temp sensor is on the passenger's side. I looked in both the service and overhaul manuals for '68 and neither shows that system. Your truck probably didn't come with it.
~Steven
Simi Valley, CA
Old 06-17-2024, 06:09 AM   #11
Getter-Done
My Ebay link was just for Example.
Thats the first thing that popped up.
Here's one on FB.
This is in aPrivate group so may not open up for you.
I can send pics.
https://www.facebook.com/groups/5126...15337351858274
As mentioned, It does not have the Emissions stuff.
84 Chevy K-20
Old 06-17-2024, 05:34 PM   #12
leddzepp
Moderator
leddzepp's Avatar
Here's one on FB.
I can send pics.
This is a correct 68 air cleaner
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
aur cleaner, big block 396, big block 402
