Exhaust coating from Eastwood
Big topic for anybody that's ever built anything with an exhaust system. Been through it all from highest cost professionally coated headers, to BBQ spray paint. I like Rustoleum BBQ spray paint on certain engines. It's cheap easy and can touch it up any time. I've just about given up on anything used on headers.
That said, I saw this pop up again today. I've seen it before but never gave it a second thought. Has anyone ever used this from Eastwood with any success? Headers or cast manifolds? Over $22 oz. !! Asking for a friend. No, really. I'm not going to be the guinea pig anymore. ![]() ![]() |
Who Changed This?
![]() Join Date: Jan 2013
Re: Exhaust coating from Eastwood
Reduces radiant heat OVER 90%!? That's hard to believe.
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Increases horsepower??!! How?
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
Who Changed This?
^ With a reduction in heat loss, velocity is not as reduced, and extraction works better. I'm still shaking my head over that heat retention claim, though.
![]() Join Date: Nov 2018
For headers, I only have used Jet Hot ceramic coatings
For stock manifolds, I used Cast Blast. Its a spray can deal and then you bake it worked well for me on a 327 |
#8 | |
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed |
There is a large amount of marketing content for this stuff out there and not very much real world usage data. Automotive forum searches turned up a lot of inquiries and folks saying they would test it but not much followup with results. Here's what I found: Here's a short discussion some members here have had: https://67-72chevytrucks.com/vboard/...d.php?t=822179 This appears to show data backing up some of the claims: https://www.onallcylinders.com/2018/...haust-coating/ Product reviews from Summit Racing (5 reviews, one is interesting): https://www.summitracing.com/parts/zyc-10008/reviews Hth, -Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
![]() Join Date: Feb 2002
Around 2007 I tried some Ceramic Coating from Eastwood, you airbrushed on, then baked for 2 hours at 500*. I coated some Hedman Hedders -- inside and out -- then mummywrapped the hedders.
Lasted 7 years before they rusted out. In Arizona. No thanks.
#13 | |
I doesn't appear that custom10nut ever posted back on coating anything. The reviews on Summit are most likely the best evidence so far. This is a response from "Zycoat Technical services" to a guy named Andy that gives it 1 star rating, says to save your money. lol "Andy / can you provide any additional detail on how you measured surface temperature before the ZyBar coating and after it was coated? What device was used? What time span were measurements taken? Any additional input you can provide would be beneficial to respond to your statements. I can tell you we have data from NHRA Top Fuel, Sprint Car circle track, Diesel Drag and Drag & Drive that prove - Significant radiant heat reduction, reduced back pressure, reduced spool time and underhood temperature reduction. Please share data that you have and we can assess your situation. Thank you, ZyCoat Technical Services" Where is the data that he/they speak of, and where is their video footage detailing the test procedure? He mentions time span. At what point in time does it actually do what it claims to do? At 10.000 rpm going 290 for 3 milliseconds??? '68Orange, not sure what you used back then. Lots of horror stories about wrapped headers rusting out quite often. Just not a fan of the wrap, even though it does keep under hood temps down. I like what headers do for performance, don't miss all the heat, going to stick to factory manifolds on my daily. FWIW, this is one of those "asking for a friend" questions for real. I actually posted this thread to get feedback for a good friend of mine that is going through this very thing on his '67 C10 as we speak. High horse SBC with coated Hedman shorty Hedders. Under hood temps off the chart. He wraps them, swears by it. This is his second pair, first pair lasted about the same time as what you speak of, about 7 years. I'm trying to help him out with something besides header wrap. I'm a firm believer in heat shields because they work. Look horrendous, but they work. Hot rodding is sometimes a compromise in form over function. Because who wants to open the hood to see a piece of nice brushed SS sheet metal covering up those rusty headers!! wait. ![]() |
#14 | |
I’ve used VHT ceramic coat on manifolds holds up fairly well . But you do have to bake them don’t think it does anything for heat .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 06-20-2024 at 08:19 AM. |
#15 |
![]() I used this on my 1967 Camaro over 30 years ago. I sandblasted the manifolds first then applied it with a brush. It has held up exceptionally well. Not sure if it's the same product as in the original post. ![]() |
#16 |
![]() ![]() Join Date: Jul 2003
I too have used the Eastwood product, and it's always exceeded my expectations.
Stanco- Your French locks on your outer manifold bolts are not bent over to prevent the bolt from backing out. Even the factory missed this at times. The lone surviving French lock on my un-rebuilt 1970 350 did not have any of the tabs bent over, and yes, those bolts were just barely hand tight.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. ![]() 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
#17 | |
Stuff was Black. Only color available then. Reasonably priced, but I had to buy a second halfpint can. I shot my Heddmans inside and out. I thought with that and my arid Arizona climate, they'd last forever. I had never tried mummy wrap before, and didn't read the fine print on my Heddman warranty. Hedders were sandblasted, then shot with brake cleaner, dried and shot with the black goop. After they were only a bit tacky, I put them both in Mom's old Hotpoint range and baked at 500*F for at least 2 hours. Paint from the upper dripped onto the lower bank. I figured that was just a cosmetic blem. [I don't think that's where the rot started. ] After putting the DEI wrap on, I did not coat the wrap with anything. I put a Mr. Goodwrench crate 350 in my '71 GMC Jimmy in 1999. The OEM ramshorn manifolds that were on the PO's SBC were mismatched. One had 4 ports -- capped off -- for A.I.R. and the other was pre-emissions. I elected for the Heddmans, as repop ramshorns were rediculously priced. Hedders were 7 - 8 years old when I coated and wrapped them. Then they lasted 7 years more. I am no longer a fan of Mummy Wrap. ![]()
#18 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
I had the Rams Head Manifolds for my new engine done by Top Gun Coatings in Calgary and they guaranteed them for life. I've only put on 13/1400 miles on the engine so far but are holding up well. They also did my Edelbrock 2101 and guaranteed it as well. https://www.topguncoatings.com
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#19 |
I never heard of it before here today. I spray professionally powder and ceramic coatings. I use ceramic coating made for exhaust and have never had a failure. Hope I didnt just jinks myself. lol That stuff is kinda high in price as well with the claims. It runs $79.99 for a 1/4 of a pint (4oz). I buy ceramic coatings made for exhaust for $70.00 a pint (16oz). As for the heat reduction I am not sure with this chemical but the ceramics I use do reduce heat. Thats why bikers love it on their exhaust.
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
