Old 07-05-2024, 05:30 PM   #1
BIG ORANGE
BIG ORANGE's Avatar
Leveling bed floor fr carpet?
Any idears on how yr leveling yr floor before placing carpet down?
I cut strips of sound deadening and placed those in the low area's of the floor, then cut the same material out and fit itin the bed over the entire floor area then put carpet down.
Unless someone has a better idear, I'm open fr suggestions.
Thanks.
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 07-05-2024, 07:07 PM   #2
Blazerowner
Blazerowner's Avatar
Re: Leveling bed floor fr carpet?
I think that’s probably the best way to do it. Strips of rubber in the slots may work since. I’m lucky enough to have leveling mats in mine. Too bad they aren’t reproduced.
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 10-04-2024, 04:34 AM   #3
87Skier
87Skier's Avatar
I bought 1/4" foam. Cut strips about 1" wide to put in the low spots, then cut the foam to fit the entire floor. I put plastic down and used 3m interior and upholstery spray adhesive to glue it together.
Then I relieved any high spots with a knife and drew a large X onto each hole that goes through the floor so I can find them easier.
I paid $145 for 175 sq ft of acoustic foam, and this used about 40-50 sq ft, so it cost about $40 for the foam and about $20 for glue.
Floor feels great. Can't tell where the high metal spots are.
Took about 8 hours to make the bed floor mat.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
