Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 01-30-2025, 07:35 PM   #1
karlbenz
C60 Hump
I'm starting to do some research on putting my cab on a f350 dually frame. the truck currently has the no hump hump. Are the bolt patterns the same as on a high hump 3/4 ton?
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
1990 Chevy Bus 8.2l fuel pincher 8800 miles
1993 Ford F350 crewcab 7.3idi nonturbo ZF5 Transmission Running on WMO
karlbenz is offline   Reply With Quote
Old 01-31-2025, 08:21 AM   #2
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: C60 Hump
C40-C60 floor hump:
C10-C30 floor hump:
By looking at these, it appears the bolt patterns are not compatible.
I would check and see if 1973-91 C40-60 humps will work in the older trucks. The floor pans appear similar.
1976:
Old 01-31-2025, 05:59 PM   #3
karlbenz
Re: C60 Hump
C40-C60 floor hump:
C10-C30 floor hump:
1976:
Yeah. the front looks totally different. The rest looks very similar. as does the 76
I converted my c10 to high hump out of a 3/4 ton. had to cut part of the floor out of the 3/4ton to do it. wonder if that may be the same deal
1965 Chevy C60
