Old 02-12-2025, 10:24 PM   #1
Malicious
Changing 73 Column Ignition switch to 67-72 Dash Ignition Switch
Hi All,
I'm in the process of installing a shorter, collapsable tilt steering column in my 73 Squarebody. I couldn't get one with a column key locally that complied with our laws, so I need to put an ignition switch in somewhere.
I was thinking about using a dash ignition from a 67-72 c10, hoping the wiring would be similar.
Looking at the wiring, I'm honestly a bit confused. Is anyone able to help me out?
It's each of the stages and what to swap to where that has me. I feel like the squarebody has a lot of swap wiring that the early one doesn't and it's throwing me off! But also I don't have a great wiring diagram to work off of for the earlier model either.
I appreciate any help y can offer. Thanks!
73+
http://www.73-87chevytrucks.com/tech...s_rr_light.jpg
What I have for a 68:
Malicious is offline   Reply With Quote
Old 02-12-2025, 10:45 PM   #2
Malicious
Re: Changing 73 Column Ignition switch to 67-72 Dash Ignition Switch
Actually I have found a local ignition switch off of a Holden - Basically Chevy (GM) in Australia.
I'm hoping I could use that? I can't find any details searching sorry!
HK Ignition switch wiring:
Old 02-14-2025, 01:00 PM   #3
kwmech
Color coding should be pretty close. I'd say go for it. I've seen some hacked up stuff that has come into the shop with just toggle switches everywhere
