‘72 v8 gas tank and sending unit compatible with ‘69 i6
Hi guys,
Local guy is selling a 1yr old gas tank and sending unit from his 1972 350 c10. I’m considering picking it up to replace the 56yr old gas tank in my ‘69 i6 (truck has sat for many years). Just want to make sure both the tank and sending unit are compatible, plug and play. I seem to remember that the later trucks have a fuel system that doesn’t vent into the atmosphere, don’t recall if that matters. I also seem to remember that some of the tanks had evaporative emissions control and some didn’t. Again, not sure that matters with the tank but I do see RockAuto has tanks with and without EEC If anyone can help confirm, that would be helpful, thanks
1969 C10 Shortbed Last edited by Luke87gt; 03-14-2025 at 03:08 AM. |
Re: ‘72 v8 gas tank and sending unit compatible with ‘69 i6
I would take a look at it for venting concerns . The tank will physically fit the sending unit will not work . The I6 has 5/16 lines and the V8 will have 3/8 so you will either have to reuse your original or buy a new one .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
![]() Join Date: Feb 2022
Venting may be an issue. Your original probably did not have vent or return lines. If the tank is out of a C10 it will have return and vent lines and the gas tank caps will be different. If the replacement tank is out of C20 or higher, then there will not be any vent lines but will have a return line and the cap will or at least should be vented.
Still plays with trucks
I don't remember what year it changed but the filler neck diameter is different at some point as well. The cab to filler neck grommet is cheap so no big deal. Just order the one for the 72 tank. The one from yours is probably hard as a rock and cracked from the years of sitting so it will probably fail when taking the old tank out.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E |
![]() Join Date: Jul 2000
Should work just fine. Just use a 3/8 to 5/16 adapter. It's what I did with my 69 that's using a 71-72 sender. (My original 307 engine used 5/16 line.)
I assume the 72 setup will be vented, so you can either deal with that, or simply cap the vent line and use a vented filler cap.
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
