Old 03-31-2026, 07:32 AM   #1
mike16
72 c10 front upper shock mount replacement
I have a 72 c10 long bed fleet side with the 307/465.
The front upper shock mounts need replacing.
Auto parts stores recommended the Dorman part number 31001.
It does not work. Its diameter is too small for the existing hole in the frame.
What are others doing to address this issue?
Other part numbers? Vendors? Solutions?
Also because the previous owner ran into the same problem and used the wrong fastener, the mounting hole in the frame is wallered out.
What solution works to fix the oversized hole?
Thanks all.
mike16 is offline   Reply With Quote
Old 03-31-2026, 10:46 AM   #2
1964FarmFreshC10
Re: 72 c10 front upper shock mount replacement
My replacement shocks came with new mounts that fit perfectly.
I know many aftermarket shocks come with them. Are you sure the hole in the frame isn't worn out and larger than it should be? That is common.
1964FarmFreshC10 is offline   Reply With Quote
Old 03-31-2026, 12:49 PM   #3
mike16
Passenger side is wallered out. Drivers side is good.
My shocks did not come with the hardware
Old Yesterday, 09:44 AM   #4
1964FarmFreshC10
You would need to repair the frame to correct the hole size.
You can order the studs seperatly.
https://classicparts.com/1963-91-sho...ww4srMl0CXH9vN
There are also aftermarket shock mount supports you can install to help prevent it from happening again.
https://classicparts.com/1963-72-sho...ckets-front-pr
