Old 01-09-2004, 03:28 PM   #1
8t5Silverado
Mudslides 'r my specialty
8t5Silverado's Avatar
LWB: Should I shorten or keep it
Here's my question.
Should I bother building a 4/5 dropped longbed or should I go ahead and make it a shortbed since I need new bedsides anyway?
(i don't know if I will find a short frame or cut mine up...)
8t5Silverado is offline   Reply With Quote
Old 01-09-2004, 03:48 PM   #2
Zilverado
Zilverado's Avatar
As I have said many times before - personally I like LWB trucks, sitting at stock height or higher. But if I can't convince you to raise it, I'd say shorten it.
IMO SWB trucks look better dropped than LWB's.
Just my $.02 though.
Zilverado is offline   Reply With Quote
Old 01-09-2004, 03:52 PM   #3
bigblock73
yeller
bigblock73's Avatar
It would be ALOT of work to shorted your lwb. As you mentioned, you would need new bedsides...then you'd need a new bed floor (expensive) PLUS you would need to shorted the frame...and unless you can weld that might be expensive as well.
I say if you want a dropped truck, buy a swb...lwb trucks don't look very nice lowered (just my opinion).
bigblock73 is offline   Reply With Quote
Old 01-09-2004, 04:34 PM   #4
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Sport truck Direct has a good pic of a dropped longbed if anyone is wondering how they look.
http://sporttruckdirect.com/Pics/85_..._Truck_Big.jpg
From this page:
http://sporttruckdirect.com/C10_kits.html
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 01-09-2004, 07:35 PM   #5
Stingray42
Woot.
Stingray42's Avatar
The longer it is...the lower it looks......
Clarkson
96 Chevy RCLB 4.3 2WD
Stingray42 is offline   Reply With Quote
Old 01-09-2004, 08:32 PM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
either leave it LWB or buy a SWB frame and start shifting stuff over. i really dont think its a good idea to shorten a truck at all
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 01-09-2004, 09:29 PM   #7
1972C10
1972C10's Avatar
Pretty easy to shorten a frame if you've got an extra LWB frame and know how much to take out the middle and how much to take off the rear.
1972C10 is offline   Reply With Quote
Old 01-09-2004, 10:28 PM   #8
76HighSierra
DAMN, I love Big Blocks!
76HighSierra's Avatar
It's not wise to fully cross-section our trucks' frame and shorten OR (for whatever reason) lengthen it. There is a high percentage of spring steel in these frames and they do NO respond well to excess heat that would be produced by welding. Notching a frame is one thing, but cross-sectioning it is not smart. Generally the heat drastically weakens the steel and makes it prone to cracking. I have seen this done before, but without fail, under constant heavy usage, the frames crack. If you plan on using your truck for what it was designed for, get another frame.
Marc Bona
Hobbs, New Mexico
1976 1/2 ton GMC High Sierra.
454 c.i.d./ TH400. *Soon to get a mild warming over.*
3.40 rear.
76HighSierra is offline   Reply With Quote
Old 01-09-2004, 10:48 PM   #9
shavedchevy
shavedchevy's Avatar
long and low is the way to go
Dennis
shavedchevy is offline   Reply With Quote
Old 01-12-2004, 03:06 PM   #10
8t5Silverado
Thanks for the info.
I can do the welding and need new bedsides anyway, but I wonder if I can get everything square.
I think I will lower the lwb and maybe look into finding a SWB frame or even a complete SWB in the future.
I will just buy only parts that can be transferred over to a SWB later (just about everything but bedsides...)
Thanks.
Old 01-12-2004, 03:11 PM   #11
8t5Silverado
I think 67-72 longbeds look good low, but I am not so sure about the 73-87s.
This one looks decent:
Old 01-12-2004, 06:26 PM   #12
1FaastC10
1FaastC10's Avatar
if i remember correctly that one is 4/5 too.
1FaastC10 is offline   Reply With Quote
Old 01-12-2004, 09:54 PM   #13
1972C10
1972C10's Avatar
Thanks.
Its pretty easy if the truck isnt on it i woudlnt think too much of shortenin it with the cab and stuff on it . i cut one down and plated it where it was cut and i cut it so it zig zaged back together so far so good main thing is getting it clamped up good and sqaure and takin plenty of diagonal measurements to insure sqaureness.
Old 01-13-2004, 12:43 AM   #14
1tonswb
1tonswb's Avatar
Shorten it!! I did mine. Took 14 inches out of the center of the frame and 6 inches off the back. Done it 6 years ago and have never had a problem with it.
1tonswb is offline   Reply With Quote
Old 01-13-2004, 05:55 AM   #15
1972C10
1972C10's Avatar
Is that the formula for a longbed 73-87 i shortened a 72 but its 12 and 6 after doing that did everything go back on or did you have to make a new rear hole for the bed?
Old 01-14-2004, 02:13 AM   #16
1tonswb
1tonswb's Avatar
Did not have to make a new hole for the bed. Short box's dont have the rear holes. Yes, it was 14 out of the center and 6 off the back. Fairly easy as long as you know what your doing. The only regret I have is I went from 20 gallon tanks to 16 gallon tanks. Not really that big of a deal though. I gained more than I lost.
Old 01-14-2004, 05:39 AM   #17
1972C10
1972C10's Avatar
Yeah i cut one and plated it where it was cut havent had any probs but i did a 72 and i had to make new holes for the rear of the bed but other than that no big deal . I havent had the chance to shorten a 73-87 but now i know the dimensions thanks..!
Old 01-14-2004, 03:14 PM   #18
ItsNotABlazer
The full convertible guy
ItsNotABlazer's Avatar
Not sure where you are from but I have a 74 shortbed frame I would let you have if you come get it. I am near Paris 100 miles NE of Dallas if you are interested. I have listed it on here a few times in the past but no real interest.
Brad
2012 Kawasaki Vaquero (Lime Green)
2000 BMW 740iL
1995 Chevy ECSB riding on air
1975 GMC Jimmy 2WD lowered 4/6
1972 Chevy Trazer soon to be roadster
1965 Mustang 289/3 speed (friends dad bought it new)
1964 Chevy C10 (dad bought it new)
ItsNotABlazer is offline   Reply With Quote
Old 01-14-2004, 03:29 PM   #19
8t5Silverado
Thanks, I would take you up on it if you were closer. I am in St. Louis.
I could just see explaining to my wife where I would be going and for what reason...
Old 03-08-2004, 01:02 AM   #20
8t5Silverado
I am reconsidering doing this...any thoughts.
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.)
http://www.cardomain.com/memberpage/500339
Old 03-08-2004, 01:31 PM   #21
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Keep it long. How many trucks out there you see are SWB lowered versus LWB lowered? If you want to lower it then keep it long and low. If I was into the lowered trucks I'd do that to my LWB.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 03-08-2004, 03:24 PM   #22
Destructo
I think a lowered long-bed looks pretty good, but in order to keep it looking good they need bigger wheels. The smaller wheels don't look good with a lowered longbed.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
