Old 02-23-2004, 12:46 AM   #1
Suicide-D
Location: Katy, TX...but the love of my life resides in Dublin,OH.
centering rear axle?? 6" drop
I used the ECE kit to do a 4/6 drop on my 70. I also replaced the trailing arm bushings with Energy Suspension polyurethane bushings. My problem is now that everything is bolted up the rear end is over to the right farther than it should be. How do I center the axle in order to tighten up the super track bar? I noticed alot of side to side play in the trailing arms before I put the bushings in. now there is hardly any play. Do I need to loosen the arms up front to get the axle centered? I didn't try this because it was getting late. Thanks in advance.
check out my updated Beater page for pics of it on the ground.
here are some pics of the driveshaft and rear end:
Suicide-D is offline   Reply With Quote
