Old 04-21-2004, 02:13 AM   #1
mudgutsandglory
Certified Truck Nut
mudgutsandglory's Avatar
4x4 conversion
i posted this under the 67-72 board too, just trying to get some responses.
i have a 1970 C10 longbed that i want to convert to 4x4, i have the front end and all the springs, what else will i need? i was planning on swapping in a 4 speed in place of the 3 speed that i currently have and using a divorced transfer out of a dodge or international, and converting to leaf spring in the back and retaining the stock 12 bolt rear end. any help would be greatly appreciated. thanks
1982 GMC Sierra Classic 1500 Longbed
350, TH350, 3.73 10 bolt
soon to be slammed
mudgutsandglory is offline   Reply With Quote
Old 04-21-2004, 05:57 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
You'll need the frame brackets to mount the springs. In the rear you'll need to fab up some brackets to mount the rear springs. The easiest would be to find a 4wd frame or rolling chassis and place your 70 c10 body on it. Your 12 bolt will nee spring pads welded on. You'd probably be better off finding a tranny/tc combo then finding a good divorced tc. Also need to cut the low hump out of the cab and find a high hump that were bolted in or install a body lift to clear the tranny shifter.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 04-25-2004, 02:32 PM   #3
ABHaulR
ABHaulR's Avatar
check this out
This is how i did it.
www.geocities.com/scbeoffroadunlimited
This was a 2wd 72 sub converted in my own drive way. it now sits
on 10" of lift with the stock trailing arms for a nice ride. it runs
18 x 39.5 x 16.5 boggers. It has a 2004r od trans gets 17.5 mpg
on the hwy. 13 around town. its been on trips to Az, Nv, and Ut.
this pic was taken in the stansbury mountains in Utah near Salt Lake City.
Dwayne
72' GMC Suburban 10 1/2" of Lift, 40" Tires! Waiting for restoration
67' Chevy, What to do???
And Bad Ass American Bulldogs!
ABHaulR is offline   Reply With Quote
