Old 04-21-2004, 11:46 PM   #1
bigskiohio
Pic of lower hose
1980 305 lower hose
bigskiohio is offline   Reply With Quote
Old 04-21-2004, 11:49 PM   #2
bigskiohio
pictures
Not sure what i did but igot this posting pictures figured out used ifanview.
Old 04-21-2004, 11:51 PM   #3
bigskiohio
you dont need to web host
you dont need to webhost pics to post at a decent size to see them clearly.
Old 04-22-2004, 12:50 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Don't forget to put hose clamps on that one.
Old 04-22-2004, 11:36 AM   #5
roadking
is your engine a 350, what waterpump do you have on long or short? and what model of vehicle is the 1980 305 bottom radiator hose for? looks like a good replacement hose for are tight fitting factory hoses. thanks
71 C10 SWB
BLACK AND WHITE
350 CRATE TH350
ENJOY LIFE
roadking is offline   Reply With Quote
Old 04-22-2004, 01:24 PM   #6
69 Short Fleet
ttt
69 Short Fleet is offline   Reply With Quote
Old 04-22-2004, 01:36 PM   #7
crazy longhorn
Fabricate till you "puke"
Roadking, i have the same style hoses on my 69. The water pump in my app is a 73-up truck item,(long pump) as are all the belts, pullies & accessories. You will also notice a difference on the lower rad neck(straight vs the curved neck on the older trucks).......crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 04-22-2004, 01:52 PM   #8
roadking
just wondering what model and make i tell the autuparts store to get that lower hose? i have a long waterpump with a staight lower neck on rad.
71 C10 SWB
BLACK AND WHITE
350 CRATE TH350
ENJOY LIFE
Old 04-22-2004, 02:09 PM   #9
crazy longhorn
Its a truck hose.....I shoot for a mid 70's (75 c-10) for a replacement hose. My 78 K20 also has the same hose. I think it would be a pretty safe bet, that 73-early 80's pu with sb will cover the same bottom hose. Good luck,crazyL
Old 04-22-2004, 06:05 PM   #10
bigskiohio
HOSE
1980 gmc 305 , everything crossmember on up is from 1980 gmc.
Old 04-22-2004, 09:11 PM   #11
Lobo'74
Lobo'74's Avatar
Fuel Line
Is that a flexible braided fuel line?
Mine is a hard line bent around and up - its not where I would have run it as the flanged edge of my metal in line fuel filter hits my valve cover. Gets a bit warm. Flex line looks like a better way to go. How do you like yours?
"Truck"
'67 small window
'79 350 .030 over, LT1 "clone"
Lobo'74 is offline   Reply With Quote
Old 04-22-2004, 09:48 PM   #12
bigskiohio
braided fueline from autozone $19.99 . It just pushes on tightens up with hose clamps and covers. cut to length with hack saw. wrap hose with tape at before cutting helps keep ends from fraying when you cut it.
Old 04-22-2004, 09:52 PM   #13
Lobo'74
Lobo'74's Avatar
"Truck"
'67 small window
Old 04-22-2004, 09:53 PM   #14
bigskiohio
fuel line
works great
