Old 04-27-2004, 08:53 PM   #1
72gmcshorty
72gmcshorty's Avatar
Can a 72 be bagged?
Can a 72 blazer 4x4 be converted to 2wd and then bagged? I think the rear would have to be leafs or is it possible to put trailing arms on it? Can a leaf setup be bagged?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 04-27-2004, 09:00 PM   #2
Faster_than_you
wow, going from up to down! totally opposites. but anyways, I would think that just a couple of brakets would be all that would have to be messed around with for the leaf springs. not exactly sure on anything else, I kinda wondered the same a few weeks ago intell I wondered why I was thinking so hard about it, when i realized that my truck is coiled.
On a positive note, anything is possible with the correct designing and imagination.
~Christopher L. Orr
71 c20, 454- Stolen While Deployed. dynoed at 550 ft lbs, 425 hp at 3000 rpm (mustang dyno). TH400 3500 stall.... etc, etc.
Faster_than_you is offline   Reply With Quote
Old 04-27-2004, 09:08 PM   #3
special70gmc
special70gmc's Avatar
it would be alot easier to switch frames im sure someone would be ready and willing to trade there 2wd frame for your 4wd and front suspention. my .2 -kyle
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 04-28-2004, 12:22 AM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Yep you could do it I have been thinking of lowering my k-5 but am gonna wait to see if I can find a 2wd... Once you get the 2wd crossmember bolted in all you would have to do is get a air ride kit for a truck with coil's front and leaf rear should not be too hard...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 04-28-2004, 08:36 PM   #5
special70gmc
o you have a blazer my mistake sorry -kyle
1958 belair 2door
