Old 04-28-2004, 08:44 PM   #1
bisquik65
bisquik65's Avatar
Thumbs up cheap engine cooker
If you need heads or a block cooked or steel wheels stripped of paint take a 55 gallon steel drum and cut it right above the first rib and put it on blocks so you can put charcoal under it . fill it with water and your parts. let the water boil and then add 2 cans of cristal driano or lye. Let cook overnight then pull it out and let it cool for about 3 hours, take it to the carwash and rince it. This way it only costs about $10. bucks. Saves you machine shop cost to clean. Been doing it for years.
bisquik65 is offline   Reply With Quote
Old 04-28-2004, 08:58 PM   #2
Gordo
Thumbs up
Cool! Sounds easy enough, I got to try that next time. Thanks!
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 04-28-2004, 08:58 PM   #3
crazy longhorn
Fabricate till you "puke"
Slick tip dude! I like cheap when building trucks crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 04-28-2004, 09:04 PM   #4
bisquik65
bisquik65's Avatar
cooker
I forgot to menton !!!!!!!!!!!!!no aluminum parts unless you want them black as coal!!!!!!!!!!!!!!. Now you can put an old engine bracket in it for an agaitior . try it and you will see how it rolls the water. I saw this idea on tv for small parts in a bucket with warm water and figured if it worked with warm why not hot?
Old 10-25-2004, 07:56 PM   #5
bisquik65
bisquik65's Avatar
ttt
useful info to save money cleaning a motor and dirty parts,wheels,ect
Old 10-25-2004, 09:51 PM   #6
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
the charcoal dont melt the bucket?
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 10-25-2004, 09:53 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Just copied to the FAQ....good info here. Bummer we can't get away with that in city limits.
Old 10-25-2004, 10:07 PM   #8
jimfulco
Just call it barbecue
An old gas water heater burner (usually found on the side of the road) works if you have gas.
jimfulco is offline   Reply With Quote
Old 10-25-2004, 10:12 PM   #9
incoma
incoma's Avatar
This is basically the hot vat that we had at the NAPA. The powder we put into the "soup" was caustic as hell. Just make sure its covered up good, b/c the vapors will peel paint. Literally. We forgot to put the lid down one afternoon and the next day all of the paint had peeled from the ceiling and walls. The owner wasn't too happy.
You can also do this with carb cleaner and use heating pads taped to the sides of the barrel. They won't boil the water/carb cleaner like the burner can, but they'll make it warm/hot.
incoma is offline   Reply With Quote
Old 10-25-2004, 10:17 PM   #10
krue
Designated A-hole!
krue's Avatar
Thanks for the tips guys! Gotta love cheap!
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 10-25-2004, 11:04 PM   #11
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
So how long will this liquid last? I mean can you do parts in it over and over,or is it just a one time thing?
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 10-25-2004, 11:39 PM   #12
1972C10
1972C10's Avatar
Local engine shops use the Lye Caustic Isnt cheap niether If a person gets the right chemicals it dont have to be heated Althou it does help to use it regularly.
1972C10 is offline   Reply With Quote
Old 10-26-2004, 05:27 PM   #13
bisquik65
bisquik65's Avatar
over and over
yes it does work over but i usually put one more can in as a booster but it does work that way. And when you have to empty it .its just like cleaning your drain out just dump it down the drain. After all its just grease in there.
Old 10-26-2004, 07:06 PM   #14
Brainchild
Brainchild's Avatar
Looks like I may have to set one of these up at the shop.I'd be nice for sure
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
Old 10-26-2004, 08:39 PM   #15
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
you could weld a hose bib in the bottom that way it could drain easily
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
