Old 04-29-2004, 12:02 PM   #1
aggiedave98
poly vs. rubber
I've read over and over and don't know what to do...
Should I use poly or rubber bushings for the front end and leaf spings???
I see arguements both ways over and over....
It's for an '89 suburban 2wd that I'm putting a 3" lift on and 32" tires. So, I don't need sports car handling...
aggiedave98 is offline   Reply With Quote
Old 04-29-2004, 06:04 PM   #2
crazy longhorn
Fabricate till you "puke"
If you are replacing susp bushings, I would go Poly. for off road use, you may be better off to keep rubber BODY bushings. I swapped poly bushings under the cab on my Longhorn, & it is a firmer ride, but for street its ok(& the clutch works much better on the tilt front truck). the rear leaf spring bushings have been up graded to poly, & I could not feel a difference in ride. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 04-29-2004, 08:28 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Don't use either one. At least not rubber or "polyurathane" because "poly" has very little flex and it will squeck like mad after a while.
What you want to use is "polygraphite", which is graphite impregnated polyurathane. It actually has graphite particles mixed in the polyurathane formula. This gives the bushing a bit more flex, and they self lubricate so they are quite too...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-04-2004, 03:55 PM   #4
ocbaud
Garage Queen Material
true that. polygraphite is gonna be so much better
ocbaud is offline   Reply With Quote
