03-31-2002, 07:29 PM | #1 |
No Gas tank filler from the Cab??
The day before yesterday, I saw a very sharp yellow truck of our era pulling out of a gas station. But I noticed that he didn't have the gas filler protruding from the cab like my 67'. Where there trucks from 67-72 that didn't have the tank behind the seat? If so...is there a way that I can convert mine? Not that I mind the pleasant smell of hi-test perfuming my cab, but the extra room behind the cab might be nice!
------------------ 67 Chevy C20 LB Stepside, 350 4-bolt with goodies.
'94 GMC Seirra Ext. Cab '67 Formula Firebird '89 GSX-R 750 |
03-31-2002, 07:37 PM | #2 |
From the factory , all the 67-72 pick ups had a tank in the cab,& the filler came out in the same place. My guess is that the guy had a burb or blazer tank under the rear of his truck. Wes or GMC Paul should be able to set you up with the parts. Good luck .....69 longhorn.
http://community.webshots.com/user/hotrodhorn |
03-31-2002, 07:38 PM | #3 |
I am a Referee of life.
One of the most disscussed topics on this board.There are several ways to do it.Some guys use a fuel cell,others find a tank that will fit and modify to make it fit.The easiest way I have found is to use the Blazer/'Burb tank.I haven't done it as I have only owned Panels which use the same tank.I think the tank kit is about $250.00.It still requires modifying a filler.You can look up pics of tennman's filler and see one of the trickest setups around.One of the vendors on the board has the tennman setup on his website.
------------------ Deland does Chevys 68Chevy panel(LIZ) "A man and his truck,it's a beautiful thing" "I have the body of a god,unfortunately it's Budda"
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
03-31-2002, 09:19 PM | #4 |
Good to know. At least there are servicable alternatives if I ever decide to change it. Thanks Fellas!
03-31-2002, 09:24 PM | #5 |
If you get street trucks mag, they recently did an article on the body work end of this conversion. There is a place that makes the filler panel for the filler neck hole which is already contoured to fit. Some options for the rear mounted filler neck are the taillight or inside the bed.
1971 Cheyenne Super Soon to be converted to '68 front clip. Efland, NC |
04-03-2002, 07:10 PM | #6 |
Gasser
Hey Cheyenne Super, I can't find the article you are referring to. Could you possibily give the company's name that makes this replacment panel for the gas filler hole?
I'm at that point now, and I'm not anxious to tackle those compound angles. Thanks, Stepside ------------------ 70 sstep tubbed, Muncie 68 swb LT-1
:thud 70 sstep tubbed, Muncie, double hump, snowflake, |
