user # 2756
![]() Join Date: Jun 2001
Couple new pics
Mounted some new tires 35-12.5R15 BFG all terrains. Ended up cost me a grand total of $40 after I sold the truck they were mounted to(a toyota w/ blown head gasket).
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() Last edited by JIMs70GMC; 05-04-2004 at 12:00 PM. |
user # 2756
From the rear
I was concerned about them rubbing but they haven't yet....
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
user # 2756
Here's both trucks:
Hope to get going on the bed next week. Waiting on the bed strips and angles.
![]() Join Date: Apr 2003
Looks good jim. What sized tires and wheels did you put on the green truck. I have a K20 with a 4 inch lift, and would like my truck to look like yours does in the background.
Thanks David
1969 K10 Custom 10 1997 Z71 2006 Volkswagen Jetta TDI 2006 King Ranch 1980 Wife |
user # 2756
Truck in the background has a 4" rough country lift and bald 35/12.5R16.5 BFG mud terrains on 16.5x9.75 chrome mod rims.
thanks, do you have any problem with the 35's you have on your GMC rubbing?
David
user # 2756
some more pics...
1 chevy/gmc truck
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() Last edited by JIMs70GMC; 05-04-2004 at 12:05 PM. |
Sorry
I guess it would do me a whole lot of good to READ your post before asking questions.
user # 2756
2
2 chevy/gmc truck
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() Last edited by JIMs70GMC; 05-04-2004 at 12:06 PM. |
user # 2756
3
3
user # 2756
4
4 chevy/gmc truck
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() Last edited by JIMs70GMC; 05-04-2004 at 12:07 PM. |
user # 2756
new 35
1 Side shot of front tire.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() Last edited by JIMs70GMC; 05-04-2004 at 12:03 PM. |
user # 2756
David, What I order and installed on my GMC were as follows: 2" heavy duty tuff country front springs and ORD 1/2 longer than stock shackles. In the rear a 2" taper block, tuff country add-a-leaf and removed the factory block. The truck has saggy butt syndrome. I measure the distance between the frame and top of the axle on the GMC and it's 12" on the green truck same measurement w/ 4" rough country springs: 12". So the Heavy duty tuff country 2" springs really netted me well over 3" because the shackles only added 1/4" lift. I'll let you know if they rub.
So you have a 2" lift with ord shackles & can fit 35 at's. Thats preety darn good a. Ive seen 4" lifts that sit just like yours. Sounds like tough country might be the way to go. Im still thinking about eaton detroit springs 3" lift. They'll even make the spring rate what ever i want. A bit pricey though.
All my trucks are gone now. ![]() ![]() |
#15 |
Geared for Collision
you mentioned something bout your truck bed jim. what is it your doing with it out of curiosity.
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB 1970 C/K20 3/4 Ton 1996 Collectors Edition Corvette 1977 Corvette Coupe |
#16 |
user # 2756
I guess all the pics uploaded have been lost.
Budweis, I bought a 67 long stepsid. It's apart in my garage now. waiting on bed strips and a the angle strips.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() Last edited by JIMs70GMC; 05-04-2004 at 12:01 PM. |
#17 |
so jim whats going on with your 33's?
are they for sale? i'd buy em if 15" wheels will fit on my 3/4 ton (i'd need some rims i guess to) |
#18 |
user # 2756
BN, you still have drums up front? If yes then the tires/wheels would fit. They are 8 lug 15x10 US wheel white wagon wheels. They are heavy, I don't know what the shipping would be and I'd have to send you some pics, they passed state inspection about 1 week ago. People around here refer to them as "stupid" swampers. They did not wear very well but have decent tread. I rotated them several times and adjusted the air pressure. They were a pain in the ass to balance also, seems like as they wear they need to be re-balanced.
#19 |
yes i have drums, factory i guess.
how many miles are on them? or how much tread? and you want to sell the wheels and tires? i thought you re used the wheels with your 35's??? anyway, im intersted, what do you want for them? zach |
#20 |
user # 2756
No the rims I used were a set of American Racing white wagon wheels. (I like the look)
I'll snap some pics and email them to you this evening, ok? Less than 10,000 miles.
