Old 05-05-2004, 04:06 AM   #1
BIG_BLAZER86
BIG_BLAZER86's Avatar
Convert 4x4 to 2wd
How hard is it to convert a 69 4x4 blazer to a 2wd, if I have the cradle. And also can the cradle be from another 2wd truck, or does it have to from the same year blazer. And does any one have a picture of one done.
81 blazer 2wd tukin 30's
07 Jeep Grand Cherokee on 26's
Tube chassis 5.3,dual T cases,54" boggers,steering rocks
Dodge 3500 with some mods
BIG_BLAZER86 is offline   Reply With Quote
Old 05-05-2004, 05:15 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
There was a couple of guys that helped me with this B 4 I changed my mind, the posts are gone now that the upgrade took place, maybe they will see this and reply? If I remember right, it was easier than I thought it would be.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 05-05-2004, 10:08 PM   #3
chevytruckfan
chevytruckfan's Avatar
Check out the post for pics of 2 wheel drive blazers. At the bottom of the 1st page a board member by the name of bigbluthng has a converted 2wd blazer. I don't know if he did it or someone else. The cradle, if you are referring to the crossmember, is the same for all year trucks from 67-early 80's to include the PUs. If it is complete then you have everything you need to bolt in. If not you will also need A arms, springs, spindles, calipers, roters, tie rod, links, etc... Good luck, I am also contemplating a swap because 2wd blazers are so hard to find. I just get a 4wd and convert it.
chevytruckfan is offline   Reply With Quote
Old 05-05-2004, 10:17 PM   #4
chevytruckfan
http://67-72chevytrucks.com/vboard/s...d.php3?t=93141
This might help
Old 05-06-2004, 09:08 PM   #5
6772king
6772king's Avatar
i have done it ... its not bad as long as you don't mind the rear leafs... the frame is to narrow to put in the coil setup without major mods... the front will bolt in once you drill holes and get rid of all the 4x4 stuff ... if it helps here is a pic a my factory 2wd jimmy and my 71 4x4 to show the diff,, mainly above the rear end the 2wd gets wider .. this is why on the one I did I just left the leaves in hope this helps
67 chevy short step 2wd 427
71 chevy short fleet 4x4 396
72 gmc jimmy 2wd 377
71 chevy blazer 4x4 454
69 chevy longhorn 5.9l cummins
72 chevy 400 2wd custom camper
67 chevy lwb 4x4 454-in pieces
67 chevy panel soon 4x4-400
67 gmc dump 4x4 1 ton-305 WTF!!
72 chevy 3/4 ton 4x4 burb 350
70 chevy panel 2wd 302 5 speed tko
"THERE IS NO REPLACMENT FOR DISPLACMENT"!!!!!!!
6772king is offline   Reply With Quote
Old 05-06-2004, 11:43 PM   #6
BIG_BLAZER86
Thanks that helps alot.
