Last week I had a problem with my headlight switch, I traced that down to the bulb in the brake light, thanks to you guys out there. But never figured out the turn signal switch problem. Well I was trying to reground my front marker lamps after my paint job and poped the fuse for the tail lights and dash lights, The wierd thing is after that fuse poped the turn signals worked like a champ, when I replace the fuse they quit working. Do anyone have any idea of whats going on with my electrical system?
The front marker lights not actually grounded. One of the leads connects to the park light side of the front light wiring and the other lead connects to the turn signal part of the wiring. If you ground either lead, you will have a problem.
The left side marker wiring connects as follows to the park/turn signal wiring, blue to blue and brown to brown. The right side marker wiring connects as follows to the park/turn signal wiring, black to blue, brown to brown. All of the wires for the markers should have been connected inside the harness. Anyway, the marker should not be grounded. Jim |
It's a catastrophic success.
![]() Join Date: Jan 2003
Also, the fuse holders get a little corroded roll you up some sandpaper and clean the insides
