Old 05-06-2004, 10:55 AM   #1
UP GRADE
one set closer
UP GRADE's Avatar
rust
my frame has some serious rust spot. can i just have the whole thing sandblasted and if so what kind of protection can i use to prevent any
furture rust.
UP GRADE is offline   Reply With Quote
Old 05-06-2004, 02:04 PM   #2
UP GRADE
one set closer
UP GRADE's Avatar
someone please help me out here.
Old 05-06-2004, 02:19 PM   #3
greasemonkey
greasemonkey's Avatar
Blasting is a good idea, then use some special rust preventative paint (i.e. POR15, Rust Encapsulator) or you can opt to have someone prime and paint it with "industrial grade" paint, or you can use farm implement paint, or you could powdercoat it, or rattlecan Rustoleum, or prime and undercoat, or spray/roll on bedliner, etc. There are a lot of options.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 05-06-2004, 05:32 PM   #4
Doug M
what ever coating you choose do it right away. The metal will flash oxidize pretty quick and you'll end up trapping moisture and rust underneath. After sandblasting the blaster should be ablt to treat the metal witha rust inhibitor.
1954 GMC 150 (for sale)
1970 GMC 1500
2004 Road King
Doug M is offline   Reply With Quote
Old 05-06-2004, 05:48 PM   #5
grayw0lf
Is Primer needed before farm implement paint?
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 05-06-2004, 05:53 PM   #6
MACKL
Almost done!
MACKL's Avatar
Dupont has a line of paint called: "Nason Automotive Finishes, Chassis Black" Part number 422-05. I was repainting the trailer for my fishing boat. It had some serious rust on it. I did not sand blast the trailer, it wasn't worth that much, I just used a wire cup on my grinder, then painted it. That was about 8 years ago and after hundreds of gravel roads and boat launches, it still looks great. It comes in a gallon can and it is pre thinned, but purchase some aeceton to clean up your paint gun. The paint did everything the guy at the paint store said it would. I think I bought it in Memphis on American Way. (Just moved to Dallas this year) Good luck!
The 1970 SWB Project
Removed 6cyl manual trans, manual everything
V8-350
Auto/PS/PDB
Blazer Fuel Tank
Behind the Marker Light Fuel Fill
MACKL is offline   Reply With Quote
Old 05-07-2004, 12:47 AM   #7
Hooter
My other Love
Hooter's Avatar
how big is the hole, cuz just welding it shut could cause the frame to crack, it would be better to fishplate the whole area and make it stronget, but if it is a small hole then i wouldnt worry as much, if you blast all the rust out of it and dont drive it in the winter, and of course paint of over it, it should be just fine
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
