Old 05-08-2004, 03:05 AM   #1
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Stepside Fender Replacement
I am redoing my stepside fenders and box. I built new flanges and will be remounting the fenders but wondering if I should use some body goo between the fenders and the box. It looks like the factory put some in there when the fenders were originally mounted. Anybody know what this stuff was and if there is a better alternative today?
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 05-08-2004, 03:53 AM   #2
JimKshortstep4x4
I used fender welting and glued it to the fenders with 3M trim adhesive. Before installing I applied Vulkem sealant to the welting. Seam does not leak but it may be difficult to remove the fender later on.
JIm
Old 05-08-2004, 08:41 AM   #3
stllookn
stllookn's Avatar
Where did you get the welting, 3M adhesive and Vulkem products?
Old 05-08-2004, 08:58 AM   #4
Mudder
Mudder's Avatar
The fender welts can be bought from most venders. The 3m adhesive can be gotten from most auto parts stores.
Mudder is offline   Reply With Quote
Old 05-08-2004, 11:27 AM   #5
JimKshortstep4x4
Smile
Vulkem is used a lot for sealing roof seams so it is good outside. It has been around for a long time and holds up well. It comes in tubes that fit caulk guns
and it is available in black and other colors. It cures to a rubber like state and stays flexible. It can be painted. It makes a very good seam sealer for applications like floor seams or weld seams where appearance is not an issue. I get mine through the local roof supplies dealers.
I am sure there are others but I have used this product for years and it holds up very well under outside weather conditions. If you have a problem locating it contact the manufacturer, Tremco Inc.
3735 Green Road
Beechwood, Ohio 44122
Telephone number 216 292-5000
In Canada the number is: 416 421-3300
Jim
Old 05-08-2004, 03:31 PM   #6
jim walker
jim walker's Avatar
The factory used a putty type material between the fender flange and bedside. 3M makes a very similar product which I used on my restoration and works great. It s called 3M Strip Calk and is available at body shop supply stores. Check it out.
jim walker is offline   Reply With Quote
Old 05-08-2004, 03:34 PM   #7
krue
Designated A-hole!
krue's Avatar
The welting that I bought from LMC is better than nothing but I really don't like the way it looks. It's just vinyl folded in half and sewed. I would try the putty type.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 05-08-2004, 07:16 PM   #8
1968GMC
love my truck
1968GMC's Avatar
Jim you got more pics of your truck?
1968GMC is offline   Reply With Quote
Old 05-09-2004, 01:06 AM   #9
stllookn
stllookn's Avatar
Thanks guys! I have been welding new flanges on all day. It is a real pain to have to cut fit every new section of flange...these were bad but they will be good as new once I am done. Jim Walker...I am guessing the thick inner flange was spot welded to the fender skin flange. Yours must have been in excellent shape...you lucky dog! This one fender will take me at least two days!
Old 05-09-2004, 10:55 AM   #10
krue
Designated A-hole!
krue's Avatar
Hey you should have seen mine when I first mounted them on the truck they were BRAND NEW! The PO had stored them in a barn since 1970 (he put toolboxes on) and they still had the putty sealer on them. Unfortunately they are the only straight panels on the whole truck.
www.daveramsey.com
Old 05-10-2004, 12:12 AM   #11
Johnny Outdoors
SOON TO BE A STEP SIDE
Johnny Outdoors's Avatar
do you have any before or after pics? or during?
im going to be doin the same repair soon
thanks
67 CHEVY LONGBED----- BEST 51 DOLLARS EVER SPENT ON EBAY!
4.3 LITER INJECTED MOTOR WITH 5 SPEED GOING IN SOON
Johnny Outdoors is offline   Reply With Quote
