The Blazer King
Convert 6 lug to 8 lug?
Is this possible? I am running an 14B FF 8 lug rear already but still have the stock front axle. Trying to find out what would be the cheapest route, converting hubs if possible or finding a 3/4 ton axle.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
![]() Join Date: Apr 2000
if you got the correct gears,i have heard that you can get a doner 10 bolt and use the 8 lug rotors and backing plate,on your axle. don`t hold me to that,i personaly haven`t done it.
but if you need gears too,then id just swap out the whole axle.. good luck jamie
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
I think there is an article about this over on http://www.coloradok5.com It should be in the Tech pages.
Edit: Here's the article http://www.coloradok5.com/8lugconversion.shtml
"When I start my car in the morning I want the neighbors to think the world is comming to an end." Homer Simpson I'm not stuck, I've still got some gas left" Last edited by fanman; 05-18-2004 at 01:02 PM. |
The Blazer King
Great write up. Thanks!!!
![]() Join Date: Mar 2003
Depends on the year of the front axle you have. Most of the time what is required is the hub/rotor assy and the backing plates--you can use the same calipers. The later model 8 lug hubs use the internal locking hubs and the large inner wheel bearing [104949] which requires the later model spindle.
