Old 05-19-2004, 07:38 AM   #1
76bonanza
76bonanza's Avatar
carb size
Do you think a holley 600 cfm is big enough for a stock 350 with headers and intake?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 05-19-2004, 10:05 AM   #2
DCRANER
With a mild cam that carb will work well, give you good everyday driveability, etc. With a little more than stock cam it would need rejetting, etc. most likely. I have a 750 because I have a ZZ430 with pretty agressive cam.
It is not so much the Holley size, meaning a 600 or 650, but how it is set up. You can make a 600 out perform a 650 or 750 that is not set up correctly for a specific engine combination.
86 GMC SWB, DK. BLUE, ZZ430,TH400, 4.11'S, HEADMAN CERAMIC HEADERS, WELD BILLETS, BFG 275 / 60 / 15, 325 / 50 / 15 DRAG RADIALS, FIBERGLASS COWL HOOD, B&M SHIFTER. MSD, MARCH PULLEYS / ALT. / PWR. STEER PUMP, BECOOL RAD., BILLET GRILL & GRANT WHEEL.
DCRANER is offline   Reply With Quote
Old 05-19-2004, 10:51 AM   #3
76bonanza
76bonanza's Avatar
I have pn 0-80457 it say this is a universal for all v-8s 1965-69. I dont want to rejet and such as it is my 4x4 daily driver no racing but still want to max. my power. Should I look into getting a new carb or working with this one?
1968 c10
lowered 3" 4"
Old 05-19-2004, 10:54 AM   #4
Crush
Active Member
Crush's Avatar
That's the same carb I'm running right now on my Blazer. It works fine for me as a daily driver and still has enough to make the drive fun.
I'm running it on a 355 with vortec heads, Air-gap intake, headers and Comp 262 cam.
If I were to change carbs right now it would probably be to the Road Demon Jr. 725.
Crush is offline   Reply With Quote
Old 05-19-2004, 11:08 AM   #5
76bonanza
76bonanza's Avatar
Why a road deamon jr and not the road deamon?
Also where on the carb can I confirm the part number?
1968 c10
lowered 3" 4"
Old 05-19-2004, 11:16 AM   #6
Crush
Active Member
Crush's Avatar
mainly price....I can get a 725 Jr. for around $275 with vac secondaries and elec choke
The same thing in a Demon 750 would run close to $400
It's my daily so I want to keep it somewhat practical....
