![]() Join Date: Jul 2003
Speedometer Cable Lube
What is the best lube for the speedometer. I have tried Lithium spray, but it did not work well.
Thanks Doug |
Go buy a small TUB of Lithium grease. Its all Ive ever used...corn
Signals in the bumper.
I have been told to use liquid graphite.
Jeff C. 1981 Chevrolet Silverado - Under major construction...again. link 1962 Chevrolet Impala 4D Sedan moredoorclassics.com 1936 Ford Pickup - Frame-off in progress link 1979 Chevrolet Camper Special Flatbed link |
I'm going for memory here (I'm not in my garage
![]() Join Date: Feb 2004
Liquid Graphite!!!
Liquid graphite is definitely the way to go. I picked up a small tube of it at O'Reilly's for just a few dollars. It's label even says "Speedometer Cable Lube". It was actually in the section of the store where the "Help!" products are. The tube is small enough and shaped to where all you have to do is pull your speedometer, stick the tube in the hole in the back where the cable comes out, and start squirting.
It's really thin stuff, and will go everywhere if you're not careful. It also stains pretty bad and is hard to get out if it gets on something you don't want it on. Mike W. ![]() |
Guys;
I just got done replacing my cable and I lubed it with the speedometer cable lube and it works great, no more bouncing speedometer. I also discovered that you can adjust the speedometer. There is a ratched arm attached to the coil spring on the speedometer that adjusts the tension. I am now only 3 miles an hour fast instead of 16. Thanks again Doug |
I don't believe that adjusting the spring tension will have any effect on the odometer reading though. But for preventing the "fun police" from ruining you day it should work great.
#8 | |
Just curious ![]() ![]() ![]() ![]() |
hmmm...i think i need some of that cable lube stuff....i checked my speedo cable for kinks or what not but didn't find any. i got about a 40mph jump after 30mph and gets bigger the faster i go...lol
Paul D. '78 C20 Scottsdale 350ci 3 speed with granny gear 14 bolt rearend My trucks are "Car-Guy safe".......which pretty much means death trap in the hands of a normal civilian. |
Paul;
The lube is great stuff, but first I would put the cable out of the housing and check it for gunk, frays, & rust first. The cable I replaced was about a year old but I did not lube it when I installed it and it rusted. I tried all sorts of different lubes and it would work about a week then start making noise. It then developed a case of the bouncey's that started at about 50 mph. I first it only did it when it was cold and would go away after about 15 miles, but last weekend it started doing it all the time, so I had to replace the cable. I thought I would let you know that lubing the cable may or may not solve your problem. Doug |
Paul;
I've got to start reading these post more closely. Hopefully your speedometer isn't bad. I'm on my third one. The one thing I've found out is if the needle jumps when you hit a bump, the speedometer is probably the culprit. Hope the lube works out for you. Oh, and 76sierraclassic is right, the lube is thin and will make a mess if you are not carefull. Doug |
