Old 05-21-2004, 02:00 PM   #1
Number98
Prestige Worldwide
Number98's Avatar
Help.....
Guys I already listed all this on the parts forum but I need a little help on what you experts think its all worth. Any replies will be appreciated.
Jason
I have a 71 C-10 that I have been working on for over a year now. I am in the midst of changing jobs and I am going to have to let it go. The truck was complete and running good when I bought it. It has usual rust in the cab. Overall the body is not in bad shape plus I have some extra body parts as well. I have a list below that list everything I have to go with it. I am sure I will forget to list some of the little things. We are doing a frame off on it so it is completely torn apart. Here goes:
71 c-10 short bed frame - has been stripped and powder coated satin black. The frame has a CPP frame notch installed, the bolt in style but we went ahead and welded it in as well. We have also cut reliefs in the main cross memeber and welded in tubing so we could route the exhaust through it and keep the pipes tucked up close. It all looks brand new, we also have all the suspesion parts and other cross members were powder coated as well. all new bushings, ball joints, etc. Here is a list of what all I have to go with it:
All new ECE brake kit
-Cross drilled front rotors
-new pre bent stainless steel brake lines
-larger rear brake upgrade
-new master cylinder
2.5" ECE dropped spindles
1.5" ECE dropped front springs
5" ECE dropped rear springs
ECE lowered front sway bar kit
ECE rear shock relocator kit
ECE adjustable rear bar kit
Complete ECE front end rebuild kit
New drop shocks
ECE stainless steel fuel tank kit
ECE transmission crossmember, plus have the original automatic cross member
New radiator
New Auburn rear differential (posi unit)
Richmond 3:42 gears
All new seals for rear end and has been rebuilt and painted
Red Line synthetic fluid
1 set of 15x8" rally wheels with 255/70 R15 tires
All new windows from Vintage Glass
original 350 engine and TH350 Transmission
1 new Goodmark LF fender
1 new Good mark drivers side door shell
Lots of little parts, new door handles, new window cranks, tail light lenses, motor mounts, door hinge rebuild kits, etc..
Have a set of headers and pipes with Dyno max mufflers that were only ran for maybe 500 miles.
I have every part and piece that came off the truck. I still have the old spindles and brake systems, air boxes, gauge cluster, bench seat, coil springs, bumpers, fuel tank, sliding back window, etc.
The truck is a short/fleet with a steel floor that is actually in pretty good shape. It is an original A/C truck. The front core support, frame, all cross memebers, upper and lower "A" frames and bumper brackets have all been powder coated satin black and look brand new.
I am not sure what to ask for all this though and am hoping you guys can help tell me what its all worth? I know my recipts and all are over $10K but you know how that is I am hoping I might can get half that and put her in a good home. Thanks for your help on this guys.
Please call for any details. I have nearly every recipt and even pictures from the tear down. I hope I listed everything.
Located in Atlanta, GA
Jason Seigler
Daytime: 770-389-7785
Cell: 404-402-8152
jrs3498@aol.com
Number98 is offline   Reply With Quote
Old 05-21-2004, 03:00 PM   #2
guyryan100
guyryan100's Avatar
Willing to part out? I'm local and could use fenders (outer and inner), rad support, tranny linkage, steering column, battery tray, power steering gears, etc.
guyryan100 is offline   Reply With Quote
Old 05-24-2004, 10:14 AM   #3
Number98
Prestige Worldwide
Number98's Avatar
I need to move it all out so I would rather find someone willing to take the whole deal off my hands first. Thanks for your interests though.
Old 06-03-2004, 05:25 PM   #4
Number98
Prestige Worldwide
Number98's Avatar
Back to the top .....
Old 06-03-2004, 07:59 PM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Hey you Atlanta boys need to check the Board Meets board.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-04-2004, 11:10 AM   #6
lamar
lamar's Avatar
Do you still have the truck or any parts I'm local.
lamar is offline   Reply With Quote
