Old 05-22-2004, 07:48 PM   #1
jerry moss
Born Psycho
jerry moss's Avatar
dana 44 with 4.56 gears for sale
thought i'd see if there was any interest here before i part it out and put it on ebay. it's out of a mid 70s 3/4 ton, disc brakes, open differential, complete except for the lockouts. it's a big hub version with big diameter axle shafts.$300.00 complete, local pick up only will not ship. if you don't like my price, i'm open to reasonable offers.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 05-22-2004, 11:47 PM   #2
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Man. I wish I had a way to get that.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 05-23-2004, 01:57 PM   #3
sakohntr
sakohntr's Avatar
shafts
Jerry, are those aftermarket "large" axle shafts ?
1967 K30 Napco 292/SM420 original paint 30k miles
1968 K60 Napco 396/5spd. dbl frame 52" michelins
1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks
1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr
1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison.
sakohntr is offline   Reply With Quote
Old 05-23-2004, 06:20 PM   #4
jerry moss
Born Psycho
jerry moss's Avatar
Bruce,
they're the stock 73 on up shafts, the inner halves are quite a bit larger than the 71-72 versions.
jerry moss
Old 05-24-2004, 12:27 PM   #5
SoCal71K20
Jerry,would the width be close to my 71K20's D44. I'm sure mounting would not be a problem with leaf springs,just wondering about rotor to rotor distance. Might even be the same. I was planning on lifting mine 4 inches. A
beefier D44 at the same time would be even better. I believe your D44 also has the stronger U-joint too.
SoCal71K20 is offline   Reply With Quote
Old 05-24-2004, 07:50 PM   #6
jerry moss
Born Psycho
jerry moss's Avatar
it's a direct bolt in for your truck, i run later axles under my own trucks. the later version is also much easier to buy replacement parts for.
jerry moss
