05-26-2004, 11:18 PM | #1 |
Next project: 1970 K10
Suggestions for aftermarket A/C system?
I plan on putting an aftermarket A/C system in the 68 before it goes to paint, or at least have it set up and ready to install. My requirements (if they can be met):
Factory vents, factory control panel, and nothing but a bulkhead on the firewall in the engine compartment. I am going to shave and smooth the firewall, so a factory system is out of the question. I have been told that Vintage Air will not work with a completely smooth firewall. Hot Rod Air has been recommended, but at this time they do not advertise a kit for our trucks. Any other thoughts? Thanks!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 05-26-2004 at 11:19 PM. Reason: Poor spelling! |
05-26-2004, 11:25 PM | #2 |
PROJECT 7DEUCE
May want to try old aire product's..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
05-26-2004, 11:47 PM | #3 |
Thanks alot, I'll look them up!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
05-27-2004, 10:20 AM | #4 |
How smooth of a firewall do you want? You can forego using the plastic piece that comes with the Vintage kit if you just want the hoses to come through the firewall and you fill in the old gaps for the heater box. I just did a Vintage Air install and thought it was a breeze to install (took 1 day including removal of the old system). I went with the factory style controller and thefactory vents. It looks great and Really blows cold.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
05-27-2004, 10:29 AM | #5 |
Insert funny comment.
Got any pics Jorgensensc?
------------ - Mark -My Build Thread... -68 C10, LT1 - Undergoing Frame off resto -86 IROC-Z T72 turbo 355, M6 -70 Camaro http://www.iroc-ss.com |
05-27-2004, 10:35 AM | #6 |
You are correct .... Hot Rod Air does not offer a kit specifically for OUR trucks. But you can purchase one of their Street Rod kits and it will do all that you stated above.
They are who I plan on using. http://www.hotrodair.com/pg1a.cfm |
05-27-2004, 10:48 AM | #7 |
Gotta Startem Early
On any of the 3 big manufacturers, Vintage Air/OldAir/HotRod Air, there will be 4 lines going from the engine compartment to the cab (for AC and Heat, just 2 if you just want AC). Those lines have to be routed through the firewall. HotRod Air has some nice bulkheads and www.gottashow.com has some nice SS lines instead of the black rubber lines. But any system will have to have the 4 lines going through the firewall.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished |
05-27-2004, 02:42 PM | #8 |
I agree with jorgensensc, my Vintage Air system took about 8 hrs total to do, including removal of the old system. I have factory vents and controller. I used the firewall panel from the kit, but I'm sure you can just run the 4 lines thru your smooth firewall if you want to.
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
05-27-2004, 03:31 PM | #9 | |
I had been told that the Vintage Air system had a protrusion through the firewall other than the bulkhead. My firewall will be flat; I will have welded all holes shut and will be totally smooth after paint. I want to be able to have it already cut for the bulkhead before I paint it. And I really don't want anything else coming through the firewall other than the bulkhead.
06-04-2004, 05:09 PM | #10 |
Check out airtique. http://www.air-tique.com/That is the system I put in. I went with the "King Kool" one. Bigger evaporator than the "other guys" You can make a smooth firewall with that one. Just run the heater and refrigerant lines to a bulkhead connector assy. on the firewall. You can get a real hi-lustre polish on that bad boy and it will look great! The TXV (expansion valve) is on the evaporator inside the truck so ther is no hardware on the outside. I have some pics if you want to see my install.
Later |
06-04-2004, 07:26 PM | #11 |
Yeah, some pics would be great! Post em here, or send me a PM. Thanks!
06-04-2004, 07:58 PM | #12 |
Send me an email and I will send them back. I have just a few pics but you can get the idea.
bud.weaver@ectinfo.com |
06-05-2004, 11:03 PM | #13 |
My kit for my truck is coming from T.B.I. (Terry Brown Industries), they have a kit for our trucks, complete with the "correct" air vents. They have quite a selection of quality products.
