Old 05-31-2004, 09:46 AM   #1
Nima
Blue 67
Lost in engine!
This is the picture of my engine and this is the number on the block behind the block on driver side: 3970010. When I used a book or one of the web site to decode this nember, I tought I have 327 engine. As far as I know, this is orginal engine on this truck (I am not 100% sure) and also as far as I know 1967 chevy trucks didn't come with 350 engines. 350 came out later. Now, when I posted a picture of part of my engine to find an answer to different problem, looks like some of memebrs have different opinion about this engine. I would appreciate any input since I am trying to buy parts for this engine I guess I need to know what it is.
Thanks.
Nima is offline   Reply With Quote
Old 05-31-2004, 09:57 AM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
69-79 350 car truck and corvette a very poplular motor as all three of my 350 powered rig's have the same casting #
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 05-31-2004, 09:59 AM   #3
Russell
Professional Grade
Russell's Avatar
the 010 is a 350 casting number
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 05-31-2004, 10:06 AM   #4
jef5150
Inline 69
jef5150's Avatar
heres a link for casting #s http://www.mortec.com/castnum.htm 3970010....302.....69....4...Z-28 Camaro
3970010....327.....69....2...Trucks and industrial
3970010....350...69-80...2 or 4
can you get the head casting #s? jeff
jef5150 is offline   Reply With Quote
Old 05-31-2004, 10:09 AM   #5
Nima
Blue 67
Thanks guys. In this case, this truck's engine is not the original one!.
Old 05-31-2004, 11:27 AM   #6
kwmech
Judging by the valve covers, the 350 appears to be from the late 70s or early 80s with the 327 intake manifold. There is a stamped code on the front of the block right in front of the right hand cyl head. These are the #s or letters that will tell you what it came out of.
Old 05-31-2004, 12:18 PM   #7
Nima
Blue 67
Well, I usually don't act this dum! but the truth is I can not find this number infront of the engine!. I am gona post some picture of the area that I am looking at at in few minutes.
Thanks though.
Old 05-31-2004, 12:24 PM   #8
Nima
Blue 67
Here are some pictures. Am I suppose to see the number around these areas?
Your help is greatly appreciated. Thanks.
Old 05-31-2004, 12:28 PM   #9
cdowns
cdowns's Avatar
chevy didn't make blue engines till the late 70's 77 ithink was the first year
Old 05-31-2004, 10:09 AM   #10
dubie
dubie's Avatar
yep, looks to be a 350 with a 2 barrel carb on it
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 05-31-2004, 06:48 PM   #11
72C203503ONTHETREE
72C203503ONTHETREE's Avatar
Actually, that blue is not the original color blue Chevy used. I had a 81 Z28 and it had the blue engine(stock) but was a lighter blue. Also, the heads after 77 were the lightwieght heads are not good for rebuilds. The oil dipstick is also on the wrong side for a pre 78 engine. Thats probably a 350 out of a caprice or Camaro.
72 Chevy C20, SOLD (Dang it.)
09 Challanger RT six speed in all black.
74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power.
73 C10 long bed, 350/350 combo, nice shape.
72C203503ONTHETREE is offline   Reply With Quote
Old 06-01-2004, 12:49 PM   #12
Cethern
What was I thinking??
Cethern's Avatar
I'm not near my 72 to go and look at my heads. But when I look at his heads I do not see any assy. Holes for stuff like the alt. would that mean the heads he has on the motor are old style? The intake is old style. My guess is someone pulled the motor and and put what ever they had laying around to make it run then used a can of ford blue to top it off. But thats just a guess.
Cethern
72 K5 that needs lots of parts..
71 GMC 3/4 4x4 That doesn't need much which is a good thing I don't think I could aford another money pit...
Cethern is offline   Reply With Quote
Old 06-01-2004, 01:54 PM   #13
70ChevyLongbed
Howzit?!?
70ChevyLongbed's Avatar
Randy's right... you can change the carb and intake regardless of which small block it is... just go easy with what you choose. My 500cfm is a great little carb too
Jason
Hawaiian-J
70 Longbed, 307, Edelbrock Carb 1404, Edelbrock Intake 2101, Dual Roller Timing chain and gears, 214/214 cam, Comp Roller Rockers, dual Flowmasters.
1999 Chevy Tahoe
2004 Mini Cooper S
71 BMW 2002 - Sold
70ChevyLongbed is offline   Reply With Quote
Old 06-01-2004, 09:33 PM   #14
72C203503ONTHETREE
Man, Im blind, yes there are no bolt holes in the heads so they are the good ones, at least rebuildable. They are pre 69 heads at least, probably the original 327 heads. If theres no numbers on the pad in front of the right head that means the block has been decked and most likely the shortblock was at least rebuilt.
