06-01-2004, 01:06 AM | #1 |
Fuse block removal
Hello everyone, I have just purchased a 67 shortbed with horrid wiring, in fact, there are 3 different ways to start the truck, (two buttons and one key start ignition switch). I am trying to pull out my fuse block, and am unable to remove it. I have removed the two screws from the inside, but can't figure out how to remove the part potruding through the firewall. Can anyone help me with this?? Thanks in advance!
06-01-2004, 01:53 AM | #2 |
fuse block
There should be a bolt on the connecter under the hood going into the cab take it out and you should have no problem. if there isn't a bolt there then they may have glued it.
1968 chevy U.S. Navy |
06-01-2004, 11:17 AM | #3 |
Ya, check the bolt its a 7/16. Then just wiggle the connection and it should come apart.
70 chev c10 swb fleet 72 grill, sb 400, 2/4 drop. 68 chev c10 swb fleet Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C Classic GM Truck Club of Washington . |
06-01-2004, 03:05 PM | #4 |
I think it must be glued, I can see where the bolt went, but there is no bolt, I'll try to pry it apart and see what happens
06-01-2004, 03:11 PM | #5 |
re
be careful, don't break it............
1971 Shortbed 350/350 w/ Posi-traction 3:73's 1996 Chevy Silverado TJ in Springfield, Virginia Likes old Chevy trucks Drinks Miller MGD |
