06-03-2004, 05:10 PM | #1 |
What Year Power Steering Gearboxes Will Work?
What year power steering gearboxes will work on our trucks? I wanted the later model with the quicker steering ratio and I didn't know what year Chevy went to metric lines.(73-8?) I was wondering before I hit the junkyards.
Thanks, Bryan |
06-03-2004, 05:58 PM | #2 |
CCRider
Anything thru 87 will work....the metric lines are no big deal....just change the fitting on the back of the pump
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
06-03-2004, 08:07 PM | #3 |
Is there any advantage in going with a newer year box, rather than a rebuilt of the correct year? Are the ratios all about the same?
DR67
Dave Knoxville,Tn. |
06-03-2004, 09:01 PM | #4 |
..i have an 80 on mine and didnt notice a difference
Ken Lyons, Slippery rock pa 68 short step 327 t10 4 gear 72 2wd blazer project 70 lwb 305/700r driver 78 caprice project 02 cavalier D.D ( hate it!!) |
06-03-2004, 09:05 PM | #5 |
I need another Barley Pop
I believe 82 was the first year they used the metric / o-ring style fitting. Could be 81, I'm having a senior moment and can't remember exactly what year.
67 Short Fleet 4x4 04 Honda CRF450R 89 Toyota 4-Runner 34 Ford 2 door sedan - Long term project ---------------------------------------------- There is a very fine line between "hobby" and "mental illness" |
06-03-2004, 09:15 PM | #6 |
ive read that the newer (73+) boxes were 1 less turn lock to lock. id really like to know. someone has to
70 longbed 496/th400/Ford 9" |
06-03-2004, 09:36 PM | #7 |
chevelito
You also have to change the coupler on the column to fit the gear box. Someone told me they don't make 'em for original non-power columns anymore.
New deadline...when my son can drive. Aloha from Honolulu, HI |
06-03-2004, 09:39 PM | #8 |
On 4WD,thru`75 is how GM has P/S box listed.That`s what I ordered.
72CheyenneSuperK20CustomCamper350/TH350,A/C 72SierreGrandeK2500350/TH350,A/C 72CustomDeluxeK20CustomCamperSB400/4SPD.A/C 72CustomC10SWB,TH400,project |
06-03-2004, 10:03 PM | #9 |
Newer boxes 3½ turns lock to lock, ours 4½ turns lock to lock.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
06-03-2004, 10:36 PM | #10 |
I'm talking about the gearbox and not the pump. Mines a 2wd and I'm going to run the 67-72 pump because I already have the brackets. I'm wondering about the gearbox itself. What years have the standard threads in the gearboxes to work with the older pump?
06-03-2004, 10:59 PM | #11 |
Project Junkie! Fishing Poor!!
You can run one up to 81. The rag joint assembly will have to be changed though. The steering shafts coming out of the 73 and newer power or manual gear boxes are smaller in diameter. I found this out the hard way, but "Red Head" Power Steering gears straitened me out. I am a dealer for them as well as using their gears. I think that I can have custom ones made, but the cost is extra. The late model gears are a full turn faster as stated above. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
06-04-2004, 08:51 AM | #12 |
PO put an '85 power steering box and pump on my '68. Wes, you say up through '81 is workable. Truck feels very touchy, especially above 45 or so. I thought it was because my frame hasn't been dimpled for the steering box. Is it possibly because it was an '85 box? What are the problems with using boxes post '81?
"Truck" '67 small window '79 350 .030 over, LT1 "clone" |
06-04-2004, 09:52 AM | #13 |
Fabricate till you "puke"
I have a 85 burb box on my longhorn, & it works fine.....the frame is dimpled on my 69 tho. The difference is the fittings on the hoses on the 80's metric boxes(otherwise they bolt up). It could be that your steering box is not centered , or in "nuetral position" when you are driving on the straight. I think it would be possible to center the box with the wheels straight, by readjusting the tierod ends on both sides. You may loose a little turn radius in 1 direction, but it shouldnt be enough to notice. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
