Tilt column & normal column compatibility
Hi Guys,
I have some problems with the tilt column I have now in the Burb I bought last year , the upper bearing ( or should I say "bushing" ? ) was already toast when I bought it , the steering wheel flies in all directions. I still have a normal ( read : no tilt ) column I took from my C-10 , is that upper bushing/bearing the same & can it be easily removed & replaced ? If no , has anyone an idea where I should buy one ( apparently not by the "columnowhateverlogist"... ![]() Are the two different columns just "bolt-ons" ( I mean electrically , are the connectors the same ? ) in those trucks , knowing that the C-10 is from 1979 and had no "Cruise Control" and the Burb is from 1987 and has "Cruise" Thanks the Baron
1982 Suburban 2WD , 260ci Olds engine,TH400 , will get a 1979 front clip , might be ready in ... 2016 1985 Chevy Van ( 305/350 ) , "Kellogg" equipped , my actual D.D. 1960 Girl Friend , frame still good , body has some dents |
Slots go on anything!
the main difference in your columns is the dimmer switch in the 87 column. The 79 has it on the floor. They won't swap out.
Thanks , Jonboy !
anyone any idea about that bushing , before I spend my time to break the 1979 column to see if it matches ? Thanks , Guys the Baron
