Old 06-09-2004, 06:52 PM   #1
76bonanza
76bonanza's Avatar
vaccum tree
You know those vaccum trees on the back of your intake with three nipples for your different vaccum lines?
Were do you get those?
Also can you get braided vaccum line for your vaccum advance cannister?
What side is this hose?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 06-09-2004, 07:09 PM   #2
TIMSPEED
TIMSPEED's Avatar
I'm sure Kragen/AutoZone/PepBoys/Napa will have those vacuum trees (Napa being my first choice) other than them, I KNOW LMC has them.
Also, try summit for the braided vacuum line.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 06-09-2004, 08:31 PM   #3
1972C10
1972C10's Avatar
If you cant find one let me know i have tons of them I try to hold out for the single ones But in the process end up with the double and triple.
1972C10 is offline   Reply With Quote
Old 06-09-2004, 08:37 PM   #4
76bonanza
76bonanza's Avatar
I need a triple one I think let me see brakes tranny and heater control ball. I looked in LMC but did not see them.
1968 c10
lowered 3" 4"
Old 06-09-2004, 08:50 PM   #5
76bonanza
76bonanza's Avatar
Anyone know the I.D. of the vaccum advance line? or the vaccum line on the holley that goes from top of carb to bottom?
1968 c10
lowered 3" 4"
Old 06-09-2004, 09:13 PM   #6
1972C10
1972C10's Avatar
5/32 i have a braided on mine but its homebrew from hell
I took some wire braid ground stuff and opened it up and put my hose inisde it and put heatshrink on the ends you cant tell the difference.
Old 06-09-2004, 09:16 PM   #7
1972C10
1972C10's Avatar
Your going to run brakes off that? all my stuff with power brakes goes on the back of the carb .
Old 06-09-2004, 09:45 PM   #8
76bonanza
76bonanza's Avatar
Ya does not matter were you run it from right as long it has constant vaccum right? My carb has no vac in rear full vac hose would have to run to passenger side front of carb.
1968 c10
lowered 3" 4"
Old 06-09-2004, 09:49 PM   #9
piecesparts
Parts and more parts
piecesparts's Avatar
I made a connection on my intake with a brass fitting that the brake lilne goes to and then I made an "Inline Tee" out of brass fitting coming off of the brake line away from the motor, thatr way I cleaned up the mess on the intake.
Old 06-09-2004, 10:50 PM   #10
1972C10
1972C10's Avatar
the vaccum "tree" im thinking of is way too small to try to run power brakes off of ..
You might be better off getting a galvinized or brass 3/8 tee and then putting the tree on one side and the power brakes on the other.
Old 06-10-2004, 09:14 AM   #11
76bonanza
76bonanza's Avatar
I think that is what I have now but the power brakes are on one side and the tree on top my problem is this set up is so high it is pressing underneth my air cleaner. When I get a new intake I am not sure it twill fit the way it is now?
1968 c10
lowered 3" 4"
Old 06-10-2004, 09:15 AM   #12
76bonanza
76bonanza's Avatar
anyone have any pics of the way theres is set up?
1968 c10
lowered 3" 4"
Old 06-10-2004, 10:27 AM   #13
76bonanza
76bonanza's Avatar
If I ran the brake booster off one side and then ran a line to a plastic tee split it one to the tranny and the other to the hearter controls. Would that be enuf vac for the tranny and the heater controls? Mainly concerened about the tranny?
Also a brass tee that would screw into the intake I can get at lowes or something?
Thanks for all your guys help.
1968 c10
lowered 3" 4"
Old 06-10-2004, 01:36 PM   #14
PHOENIX
You can get vacuum trees and thermal vacuum switches from your GM dealer.
Brakes need full manifold vacuum.
You can probably find a brass fitting that will work at Lowes or home depot. Look in the plumbing section though, you will probably not find the right size in the hardware section.
Ill see if I can get you a picture of what I have going on. I am pretty sure I have the brake vacuum connecting to the back of the carb though (I know you dont have this option). But I do have a 90 vacuum fitting (full manifold vacuum) between the carb and distr., Ill see whats going on and get a picture if possible. The 90 fitting I am talking about it probably too small for a brake vacuum line though.
If you have a port available on your intake manifold I would hook the brake vacuum line up there and alone if possible.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 06-10-2004, 01:42 PM   #15
76bonanza
76bonanza's Avatar
I have one manifold vaccum hole on my intake. It has my brakes on one side and on top a tree with my tranny and my heater. It all seems to work fine it is just very tall tring to clean it up and make it shorter I will take a pick of mine. I have a full manifold on the front of my carb. But dont really want to run another vac hose from front of carb all the way to back.
1968 c10
lowered 3" 4"
Old 06-18-2004, 12:56 AM   #16
Baralheia
Baralheia's Avatar
I can confirm GM parts departments still carry the correct application manifold vacuum fittings, or at least one that will be compatible. I just purchased a fitting, GM P/N 14069089, that has 5 ports: the top three (small to TVS, top to trans modulator, large to A/C / Cruise) as well as two more large nipples on the lower flange. GM List is $6.42 USD.
You might be able to get the exact part for your application; check with your local GM parts department for pricing and availability.
Baralheia is offline   Reply With Quote
