06-10-2004, 07:20 PM | #1 |
9 months
Still a lil' new to this
I finally got my LMC catalog for 73-87 trucks. I know that its said these trucks have inter-changeable parts, and I'm sure I can order the gauges and lines to replace my old light up ones with only pic and red light. But I'm wondering if I could still order these wheel wells and grille to fit on my 1 ton, when they only designate 1/2 and 3/4 ton trucks. And what about floor pans that they only designate for lighter trucks?
06-10-2004, 07:53 PM | #2 |
Professional Grade
The cabs from 73-80 are the same, the beds are the same (minus possible bolt locations) , the front fenders are the same from 73-80, the inner fenders from 73-80, and the grills were often different from year to year.
Anything that I said was the same from 73-80 means that everything from 81-87 is also the same, basically split into two year ranges, some parts will go between any truck, and some will only fit one year. The easiest way to tell the difference is to look at the marker lights on the front fenders -- Vertical = 73-80, horizontal = 81-87 As far as the instrumentation goes, make sure that you get a bezel with either an amp or voltage gauge depending on which one you have, aka, if you have an amp gauge, get an amp gauge bezel, vice versa. Some gauges are electric, some are mechanical, also watch for that... While you've got stuff apart, go buy a can of chrome rattle can paint, and spray it onto the blue parts of your dash bezel, you'd be amazed at how much brighter it will all be...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
06-10-2004, 08:40 PM | #3 | |
the wheelwells will work on your truck, and if you have a 1 ton 2wd the floorpans should be the same as well. |
06-10-2004, 09:56 PM | #4 |
www.73-87chevytrucks.com
You are going to need the printed circuit to switch from idiot light to guages. Also, only certain guages will work with certain years. Also, check this page Crossy put together for more info. http://www.73-87.com/7387garage/inte...achometers.htm
Shameless plug for my company, but compare my prices to LMC's http://www.73-87chevytrucks.com
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
06-10-2004, 10:45 PM | #5 |
9 months
Thanks guys.
So Russel, you're saying that I could go to the junkyard and take off the front feneders from a '77 C10 and fit my '80 C30 by checking the marker lights? Thats really cool they can be singled out and identified easily. Jeremy, thanks. I'm going to order the wheel wells tomorrow. Maybe also look out at junkyard for floorpans before I order them. Will try pm'in Crossy. Chris, thanks, read over Crossy's review, helped a lot. And have checked out your website. Noted down a few things that would really spice up my old beater. And sorry it seems like I'm draggin on and on, just started second of two jobs today and for some odd reason actually have tons of energy left. If only it were daylight right now.... |
06-10-2004, 10:52 PM | #6 |
9 months
Also wanted to thank guys at LMC for this catalog. Really helpful with not only parts, but assemblies and identifying parts. Really recommend.
06-11-2004, 02:41 AM | #7 |
Right turn Clyde
80 was an odd year, Im not sure if the fender will bolt up to the core support.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
06-11-2004, 02:51 AM | #8 |
9 months
Meaning its just plainly impossible or mods would be needed? Since you're up, it seems, are you watchin outdoor channel? Good episode of rebuildin military 4x4s.
06-11-2004, 02:55 AM | #9 |
Right turn Clyde
There might not be any problems at all. But I know that 80 was an odd year it has older style fenders and newer style core support. I was thinking since it has the new core support that it might cause a problem. Im not 100% sure tho
06-11-2004, 03:04 AM | #10 |
Right turn Clyde
Just missed the show, I didnt know anything about it till it was to late.
06-11-2004, 03:27 AM | #11 |
9 months
Oh. Well i'll just try and see what i come out with. Seems like my truck just borderlines everything needed. It's soooo special! :p
j/k thanks bowtie. |
06-11-2004, 08:30 AM | #12 |
You get what you pay for
Fenders didn't change shape until 81 so any 73-80 fender will fit. It's true in 80 some trucks used round headlights and some used square, but the fenders are the same as 73-79.
Mike 1985 Chevy C-10 |
06-11-2004, 09:56 AM | #13 | |
Professional Grade
06-11-2004, 11:02 AM | #14 | |
06-11-2004, 12:16 PM | #15 |
All of the 73-87 body parts interchange you just have to know how to do that. The 73-80 interchange at the part for part level as do the 81-87's. Between series 73-80 and 81-87 fit but can require groups of parts to make the swap. This includes fenders, hood's cab's, bed's etc. All of the 10, 20 sheetmetal fit the 30 series. The cabs from 73-80 are either 2wd or 4wd cabs. The cabs from 81-87 are all the same, basically a 2wd or universal cab. The frames are different from series to series, but basically the same with minor differences from 73-87 or at least all those I have seen are.
What year stock grille and fenders are you looking for? I may have them and I'm about 35 miles from Gahanna. I do mostly K30 and C30's if you have any questions. BTW there are no 73-87 Chevy trucks in any Columbus area junkyard. They were crushed long ago and the ones that weren't probably don't have enough steel left in them to hold a magnet. Email me at videos@bright.net if you are intertested. |
06-11-2004, 12:20 PM | #16 |
LMC made a lot of money from me. Great stuff!
