06-17-2004, 06:07 PM | #1 |
What if??
I take the front coil springs and rear leafs out of a half ton and put them in my 3/4 ton, will that give my truck the same ride height of a half ton? Is that the only thing that makes the ride height higher on my 3/4? Will there be any problem with doing this, driveshaft angle,etc? Thanks for any input.
06-18-2004, 07:43 PM | #2 |
Nobody? Any ideas on where I could find out for sure on this? Thanks
06-18-2004, 07:51 PM | #3 |
ndchevyman
I think that the a-frames on the 3/4 ton's are different from the 1/2 ton's. Some of the 1/2 tons had heavier springs that could have been ordered as an option from the factory. Sounds like it may be worth a try. You could always ask some of the specialist like earlyclassic If you do not get any response.
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
06-18-2004, 09:22 PM | #4 |
Fabricate till you "puke"
I asked my little bro "what if".....he said what if toads had wings? I said "dunno".....he said they woudnt have to bump their @sses on the ground all the time sorry, couldnt pass that up at any rate, i have done the drop thing on the old longhorn, & added 5 lug 1/2 ton pcs. at the rear, i tossed all but the top 4 leafs , & flipped the rear diff(12 bolt now), & relocated the spring perches to raise her back up just a tad. My guess is about a 4 1/2 - 5" drop. slapper bars were added to handle the wheel hop. the front was done with a cut coil (1 full ring off the bottom), & looks to be a 2 1/2 -3 " drop(also 5 lug 1/2 ton pcs up front). the springs i cut were new, but the lightest I could get, as per my local spring shops advice. when you cut them, they get effectively stiffer. You can do the 5 lug swap aftermarket, but factory pcs are really cheap to get. any ?, or further "crazy info", feel free to drop a PM, & I will help if i can here is a link to a few shots on my "3/4 ton low rider" http://community.webshots.com/user/hotrodhorn best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
