06-20-2004, 02:28 AM | #1 |
Jimmy vs Shortbox frames
Hello, I was wondering if there is any differences between a 1971 Jimmy 4x4 frame and the frame for a 71 Shortbox 4x4. I'm asking because I just recently bought a 71 Jimmy that had a 69 cab put on it years ago and I was wondering if I could somehow put a shortbox box on it without any major modifications. Thanks for your help.
06-20-2004, 06:19 AM | #2 |
The Jimmy frame is 11" shorter than the short box frame. The short box has a 115" wheel base and the Jimmy has a 104" wheel base. I believe that some of the body frame mounts are different, also.
Lengthening the frame may be considered as major, I guess, but it could be done. Whether it would be worth it is another question. Jim Bouncytruck is right the wheel base is 104". Last edited by JimKshortstep4x4; 06-22-2004 at 06:52 AM. Reason: Correct wheel base |
06-20-2004, 07:20 AM | #3 |
Shortbox
Another option would be to shorten the already short shortbox
IMO, I'd do the frame though. All depends on what you consider 'major' and your welding skills. |
06-20-2004, 11:45 AM | #4 |
huh ???
The Blazer/Jimmy wheelbase should be 104 inches...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
06-20-2004, 03:06 PM | #5 |
SKINNY TIRES RULE!
Find a Blazer or Jimmy tub and put it on there... Blazers & Jimmy's are much cooler than pickups anyway
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
06-20-2004, 10:32 PM | #6 |
Yup, 104" wb on the 69-72. Also, the rear of a Blazer frame turns down and has built in center mounts for the bumper. The shortie frame sticks out straight and all bumper mounts bolt to the frame.
06-20-2004, 11:41 PM | #7 |
huh ???
My 71 Blazer frame came out straight and had bolt on rear bumper brackets...
Chuck
