How to get C10 2WD short/fleet to hook...
How can I go about that if I've already got:
383: 4-bolt main block Eagle 3.75" 4340 crank w/ 6.0" 4340 rods SRP forged dished pistons 10:1 Comp Cam XE274 w/ Magnum roller rockers 1.6 ratio Dart Iron Eagle 200cc heads 2.02/1.60 Speed Demon 750 mech. secondaries I'd LIKE to pull 12's in the 1/4 when the motor is finally broken in. I'm open for any suggestions.
'71 Chevrolet C10 shortbed - 414" LQ9/4L80e/S91 turbo --- PROJECT! '99 Chevrolet Camaro Z28 A4 Yank 4200 stall/AZPS 03 cam (242/248 .621"/.615" @ .050" lift)/UMI 4130 suspension/True Duals/Moser 9" 3.73/AR Torq Thrust M's Black |
what transmission, rear gears, and tires are you running?
Brian Pal 1971 Cheyenne 10 454/th400-Undergoing a full frame off resto. 1972 Chevy short/step 2wd, 350/th350 1983 M1009 CUCV Military K5 Blazer 1981 Dodge 1 ton 4x4 dually flatbed |
With that engine, coupled with a Th350, along with a posi rear end with gears in the 3.4x-4.1x, and a good hook, I can GURAN-DAMN-TEE you'll go 12's!
If you got leaf springs in the back, I would recommend a flip kit, with spring clamps in front of the axle. |
Trans: TH400 Hughes-built w/ 2500 stall
Rear end: 3.73 Eaton posi 12-bolt rear Tires: 295/60/15R BFG Drag Radials
I have almost the exact same setup. Where can i get a flip kit for it??
#6 | |
By the way, I AM running coils. Any way I could get the hook I want without going to a flip kit w/ leafs?
Fabricate till you "puke"
Your coil setup will hook much better than the leafs, & much less hassles. The long trail arms make a good traction bar. It sounds like you have the rubber on the back, but may find that the truck will hook better on the strip than on the street.....i would take it out & run it after you get the fresh mill broke in, see how it does, & work from there
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Go to www.hotrodstohell.net and check out the truck arm upgrade kit. I just ordered one and will post results...
#10 | |
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
My only concern about HotRodsToHell's kit is that I already have the complete 4/6 drop kit from Early Classic, which has springs, shocks, shock mount relocator, and drop spindles. How would this interfere with HotRodsToHell's kit?
