Old 06-21-2004, 11:11 AM   #1
WB72
Before and After
WB72's Avatar
HEI and Header Questions
I know that the swap for the HEI unit is a no-brainer, but will I have to recurve the unit for the engine that I am building?
Are the exhaust ports all the same on all Small blocks? even the Vortecs?
Are there any sites that would give me info for the distributor question.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 06-21-2004, 03:01 PM   #2
busterwivell
HEI's are a drop in, nothing else to do (except make sure you aren't off a gear or something)
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 06-21-2004, 04:30 PM   #3
cdowns
cdowns's Avatar
you do have to run a new power wire for an hei to eliminate the resistor wire as well as eliminate the yellow wire from the starter
Old 06-21-2004, 07:03 PM   #4
crazy longhorn
Fabricate till you "puke"
i agree with both guys on the HEI, its a pretty bolt in swap, with addition of a wire from IGN unfused in the fuse box(full batt voltage). As far as a recurve, it will help your power band & mileage. Crane puts out a nice kit , vac advance can + springs for the mech advance.....the instruction is also good! It will take a little time 1st time around, but after a time or 2 , you will have a new "trick" that you can keep As far as ports & header match up, you should be ok for most apps.....if you try to run some monster heads , like a 12 or 18 degree (roundy pounder stuff), you will have issues with headers. Best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
