Old 04-04-2002, 04:29 PM   #1
67c-20
Post body bushings
i am about to replace the body bushing on my 67 3/4 4x4. i was just wondering if there is an easy way to go about it. if there is anything i should do befor i start. or maybe what order to go in.
67 k-20 w/327 and a 3speed and 4.57 rear with 17 inch split rims and 9 inch wide rubber(is my current project)
73 blazer 6 inch all spring lift 350/350 with crappy 3.08 gears and 35 inch bfg tires
54 chevy delray .060 over 250 i-6 which was taken from my first truck(68 gmc)
73 blazer 6 inch all spring lift 350/350 with crappy 3.08 gears and 35 inch bfg tires. just put out 135 hp to the wheels on the dyno.
54 chevy delray .060 over 250 i-6 which was taken from my first truck(68 gmc). it is next in line for a rebuild
67c-20 is offline   Reply With Quote
Old 04-04-2002, 05:33 PM   #2
Luckymic34
Whisky Bent & Hell Bound
Luckymic34's Avatar
Post
Wow, there's body bushings!
I just ran out to look...no such thing. LOL
[This message has been edited by Luckymic34 (edited April 04, 2002).]
68 custom stepside PS,PB
350 with Vortec Heads,Carter 650, Edelbrock Performer,HEI,
Crane Enegizer 266, Headmen headers
40 series Flowmasters, B&M hole shot
2,000 rmp stall, TCI TH350 Streetfighter,
4.10 gears
2003 Harley Davidson 883C
San Diego, CA by way of
Houston, TX
Luckymic34 is offline   Reply With Quote
Old 04-04-2002, 05:35 PM   #3
67c-20
Post
thats what i said when i looked under my friends truck. lol. just had to get me some.
Old 04-04-2002, 08:30 PM   #4
Southpa
Southpa's Avatar
Post
Are you refering to cab mounts? ie. the large bolts that hold the cab to the frame with large rubber cushions in between.
Southpa
1970 GMC 1500 Custom
Victoria, BC, Canada
Original 350/TH350
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 04-04-2002, 08:43 PM   #5
bigvinnie
bigvinnie's Avatar
Post
if you're replacing cab mounts, best way is to remove both bolts on one side and jack it up, using a 2 ft. 2X4 between cab and jack to distribute the force... replace the mounts, tighten the bolts, but not all the way... then do the other side in the same manner... now you can crank all 4 down good and tight. Remember you also have some mounts under the radiator support. Good Luck.
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
http://www.ixpres.com/vlusardi/chevtrk.htm
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 04-04-2002, 09:32 PM   #6
67c-20
Post
thanks big vinnie that is what i was thinking. yes i was refering to the rubber cab mounts. i started on the pass side the back one came out easy but i twisted a 1/2 inch extension off trying to get the front one out is there something i missed or is it just rusted in that bad. i have never twisted a 1/2 extension off before. it is a craftsman so no biggie right? i think it is time for the cut off wheel.
Old 04-04-2002, 09:37 PM   #7
Jim68
Jim68's Avatar
Talking
Yeah 67c-20, they get rusted on there pretty tight, I think I had to cut one of my front ones off and the other one took me and my friend pulling on opposite sides of a tire iron to get it undone. Gosh that was a pain in the a$$. Just cut em off. You'll want new hardware anyway. Have fun.
68 long fleetside C-10, '74 350, CH465 4-speed, Edelbrock Performer 1406 Carb, Hedman Hedders, 50 Series Flowmasters
Mesa, AZ
[This message has been edited by Jim68 (edited April 04, 2002).]
Mesa, AZ
Jim68 is offline   Reply With Quote
