What I drive
Hooking a kick down(detent) cable to an Edlebrock carb
Just got my tranny from the shop and the guy told me to hook up the kick down cable. I got home and the carb I have is an edlebrock 1405. The throttle bracket is there and has the square hole for the kick down cable but where would it hook to on the carb?
1986 Chevy Crew Cab Dually(Choo-Choo Conversion) 2006 Chevy Equinox |
you can hook the kickdown cabel to the lower lever below were you hookup the throttle cabel. I hope this helps. I just did it last week an edelbrock 1406
What I drive
In the hole in the throttle arm below the accelerator cable? That is where my return spring is connected..........so where would I move that to. Also would the stock cable work or do I need to get a universal cable. Thanks for the quick reply
Garage Queen Material
![]() thats how i have mine hooked up. i had to order a little stud for the carb though |
What I drive
Where did you get the stud OC? My throttle are looks different. Where yours has the big hole up and to the left of the accel cable mine is below the cable...same hole and my return spring is hooked in there.
Good pic. When I installed mine my cablethe throttle cablewas at a sever angle. I tried a new bracket that mounts to the carb. That kinked the cable. I ended up going with the Lokar setup. New Throttle and kickdown cable. It's a sweet setup.
what trans do you have? what you may be dealing with isnt a kickdown cable at all, if its a TV cable, you're in trouble if it isnt hooked up.
my bracket is an edelbrock bracket, not the stock one. i ordered it all from jegs. i'll get you parts numbers for the bracket and stud if you want them
i havent ever had mine hooked up
will not using it effect the transmisson. its getting rebuilt right now and i wasnt going to hook it up, but if it will damage my new stuff i could hook it up
79 chevy k20 350/350/205/D44/14bFF 4.56 gears rock ![]() LWB pimer black 01 S-10 ZR2 extended cab 4.3/4L60E/233 3.73 gear 31" DICK CEPEK CRUSHERS |
if you have a 700r4 it will screw it up bad. if its a th350/400, it wont hurt anything
What I drive
I went and looked at my throttle arm yesterday and it's the same as your oc. 1faastc10 I have the th-350c. It's the detent cable. The guy that built my transmission said that it was important to hook it up. Oc.....i thought it controlled line pressure? Now what cable should I get.......a stock one?
if you have a th350c, the same tranny i have, you dont have to have the kickdown cable hooked up. the detent cable on a 700r4 is very important to use though.
What I drive
Are you not using yours? My builder told me it was important........now I'm confused
i am using mine. in the picture i posted, it is the cable that is going to the same place the return spring is located.
all it is supposed to do is shift the tranny down a gear or two depending on how much gas you give it |
#15 |
What I drive
did you use your stock cable?
#16 | |
#17 |
i ran a stock cable with mine too, after i rebuilt the engine and trans. the two trannys previous to this one (one is still going with no cable hooked up, 80K on the trans last time i heard, and never a problem out of it) didnt have it hooked up. the second one i had the pump went south and fried the clutches.
#18 |
Right turn Clyde
Hook up the detent cable its not that hard. It does adjust line pressure in conjunction with the shifts depending on throttle. It isn't mandatory to have the detent cable hooked up. But I dont see what the advantage or reasoning is to not hooking the detent cable up? It was designed for it to be used so the transmission can function better.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
#19 |
What I drive
Anyone know if that mounting stud can be purchased locally?
#20 | |
#21 |
What I drive
Got it going!
Runs good and shifts great even without the cable..........it is to long
