06-29-2004, 11:46 PM | #1 |
88 S10 V8 (tn)
88 S10 V8 - $1,900 obo/trade
Here's the specs on the truck: - 1988 S10 SWB std Cab, Red - '74 350 2 bolt main (std bore (checked by machinist, no overbore was needed), new rings/bearings/etc, 282 cam, alum intake, new 1 wire alt., some chrome accessories), heads were in good shape (put new seals in), new battery, new headers, Carter AFB carb, JTR motor mounts, rebuilt HEI w/curve kit, new radiator, new flex fan, engine has been broken in...sounds great - TH350, worked good in the truck it was in (replaced seals & filter, added chrome pan w/ drain plug), driveshaft cut and balanced w/ new ujoints, new B&M Zgate shifter, 2500 stall TCI converter - Lowered w/ 2" blocks in the rear and new 3" DJM springs in the front, new shocks, manual brakes and steering, new 15x8.5/15x4 Centerline whls, new tires, traction bars (not installed) - Body is in decent shape...I replaced the cab corner. Most of the frame has been sandblasted and painted. There's a couple dents, nothing major. Needs paint. New late model grill. Extra hood. No tailgate. Crack in windshield. - Interior is completely stripped except for the stock bench seat & door panels. I have some decent Blazer buckets to go with it. Passenger side of firewall cut out for header/trans clearance, almost finished closing it in w/ sheet metal. New small 3 guage panel & large tach. Very little work to be ready to race. Pics available. Located in Dickson, TN |
